I was messing around with python3 and pip, and some packages seem to have corrupted some of the python files, i am getting this error and some others when trying to use pip :
Exception:
Traceback (most recent call last):
  File "/usr/local/lib/python3.8/dist-packages/pip/basecommand.py", line 209, in main
    status = self.run(options, args)
  File "/usr/local/lib/python3.8/dist-packages/pip/commands/install.py", line 249, in run
    with self._build_session(options) as session:
  File "/usr/local/lib/python3.8/dist-packages/pip/basecommand.py", line 66, in _build_session
    session = PipSession(
  File "/usr/local/lib/python3.8/dist-packages/pip/download.py", line 321, in __init__
    self.headers["User-Agent"] = user_agent()
  File "/usr/local/lib/python3.8/dist-packages/pip/download.py", line 93, in user_agent
    zip(["name", "version", "id"], platform.linux_distribution()),
AttributeError: module 'platform' has no attribute 'linux_distribution'
  File "/usr/lib/python3.8/runpy.py", line 194, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/lib/python3.8/runpy.py", line 87, in _run_code
    exec(code, run_globals)
  File "/usr/local/lib/python3.8/dist-packages/pip/__main__.py", line 19, in <module>
    sys.exit(pip.main())
  File "/usr/local/lib/python3.8/dist-packages/pip/__init__.py", line 217, in main
    return command.main(cmd_args)
  File "/usr/local/lib/python3.8/dist-packages/pip/basecommand.py", line 242, in main
I tried hours using the suggested methods on related questions but non of them helped
based on some threads, you should not remove python3.8 because many system resources use it, so how can i repair all of it files and reinstall it? i want it to basically revert back to default and remove all the installed packages, how can i do it?
You need not have to remove python3. It will just make the matters worse. Instead, remove pip and install it again following the command below.
sudo apt remove python3-pip
sudo python3.8 -m easy_install pip
