19
How do I remove Mono from my Ubuntu installation?
Which applications depend on Mono? Could you suggest me some alternatives?
Jorge Castro
  • 73,717
sudobash
  • 1,064
10.04
First Things First: The list of applications that will be removed if you remove Mono:
  • Tomboy
  • gBrainy (I'm not sure if an alternative exists)
  • Docky
  • Gnome Do
  • Banshee
  • F-Spot
Alternative Applications:
  • Tomboy alternative:
    GNote Install gnote: sudo apt-get install gnote
  • Docky alternatives:
    Avant Window Navigator Install avant-window-navigator: sudo apt-get install avant-window-navigator
    Cairo Dock Install cairo-dock: sudo apt-get install cairo-dock
  • Gnome Do alternative:
    Kupfer Install kupfer: sudo apt-get install kupfer
  • Banshee alternatives:
    Clementine Music Player: http://www.clementine-player.org/
    Rhythmbox Install rhythmbox: sudo apt-get install rhythmbox
    Exaile Install exaile: sudo apt-get install exaile
    Amarok Install amarok(KDE application): sudo apt-get install amarok
  • F-Spot alternatives:
    Shotwell Install shotwell: sudo apt-get install shotwell
    Digikam Install digikam(KDE application): sudo apt-get install digikam
Mono Removal:
  1. Make a backup of all your data associated with Mono applications.
  2. sudo apt-get purge libmono* libgdiplus cli-common libglitz-glx1 libglitz1
Sid
  • 10,643
17
12.04
For Ubuntu 12.04 if you want to remove the complete mono packages you need to remove mono-runtime
sudo apt-get purge mono-runtime
This is the base package and should recursively remove all packages which need it
Manish Sinha
  • 11,671
