I recently switched from CentOS to Ubuntu. Grub can find my old CentOS /root XFS partition but fails to load it. At the emergency mode prompt I can manually mount the old centOS partition.
The journalctl log seem to imply that Grub thinks the partition is ext3 but it is XFS.
journalctl says
systemd[1]: Found device /dev/dm-5.
systemd[1]: Starting File System Check on /dev/dm-5...
systemd-fsck[2496]: fsck.ext3 doesn't exist, not checking file system on /dev/dm-5
systemd[1]: Started File System Check on /dev/dm-5.
systemd[1]: Started dracut initqueue hook.
systemd[1]: Reached target Remote File Systems (Pre).
systemd[1]: Reached target Remote File Systems.
systemd[1]: Mounting /sysroot...
mount[2522]: mount: unknown filesystem type 'ext3'
systemd[1]: sysroot.mount mount process exited, code=exited status=32
systemd[1]: Failed to mount /sysroot.
systemd[1]: Dependency failed for Initrd Root File System.
