I'm trying to install ubuntu from a 4Gb partition I created (virtual USB). It is supposed to work as an external USB stick. I have done that before, several times, using this same machine. But for some reason I'm no longer able to repeat the process.
First problem: No matter how hard I try, I cannot get the machine to boot directly from the virtual USB. I put the boot flag to that partition. It doesn't work. I used a Grub4Dos menu to point to that partition (the ubuntu install), it starts in text mode and never reach the graphic installation, It shows long lines telling what's going on and at some point it completely stops. In the latter lines I see some errors referring files or paths not found. It shouldn't happen, everything is there.
What's happening now?
- Same machine.
- Same configuration in the machine setup (almost sure / I tried also default setup).
- Same ISO file (no doubts here).
- I made some changes in the partitions, but that shouldn't be the problem (Nonetheless I tried to rollback most of the changes).
I'm stuck here. A solution may be to buy a USB stick, a problem I had already overcome.
