Since wifi-radar is not yet available on ubuntu 20.04, I go to explain my need
I have two WiFi networks, the main WiFi has SSID Main
the other is a sort of backup and it has a low signal and poor performance, let's call its SSID Emerg
Sometime the Main SSID becomes unavailable I suppose for some sort of interference, so I manually switch to connect to the Emerg WiFi
When Main returns available ... obviously the WiFi remains connected to the Emerg
Well here it comes the question
Is it possible to setup the WiFi in such a way that when Main SSID returns available, the WiFi goes automatically back to connect to Main ?
Robert
  • 177
Create a new script with :
sudo nano /usr/local/bin/back-wifi-main
Paste the following content (replace by your Wifi password)
#!/bin/bash
Get the current Wifi
current=$(iwconfig 2>/dev/null | grep ESSID | cut -f 2 -d ")
if [ $current == "Emerg" ] ; then # Check if Wifi is back if nmcli d wifi list | grep '^\ ' | grep "Main" ; then # Reconnect to your wifi nmcli d wifi connect Main <password> fi fi
Make it executable
sudo chmod +x /usr/local/bin/back-wifi-main
Finally add this script into a crontab
sudo crontab -e
and paste the following content to check every 5 minutes
*/5 * * * * /usr/local/bin/back-wifi-main
anonymous2
  • 4,325
ob2
  • 3,653
