If I as root in Nautilus at the top directory open the properties I get:
Type: Folder (inode/directory)
Contents: 1 560 503 items, totalling 414,8 GB
Trying root@nilx:/# locate * | wc I get
2997356 3450407 217324980
and root@nilx:/# tree -ia gives me
277432 directories, 3293850 files
(directories+files=277432+3293850=3571282)
So how many files do I have?
user37342
  • 309
locate is not suitable to count files!
It relies on what is saved in the updatedb database. But it leaves out some directories from the database when scanning. See /etc/updatedb.conf
PRUNEPATHS="/tmp /var/spool /media /var/lib/os-prober /var/lib/ceph /home/.ecryptfs /var/lib/schroot".
Nautilus defaults to not include hidden files in the Contents/Totalling section, you have to explicitly enable "show hidden files". Also it does not decend into other file systems, it does report the same as tree -ixa / though.
tree should work just fine.
But you could also use find, which should be faster than tree:
find / -printf . | wc -c
pLumo
  • 27,991
