In addition to the other storage devices on my laptop, running df -h displays /cow as one of the devices. What does this mean?
Jeff
  • 1,724
Beldar
  • 41
I think you are running a live (live-only or persistent live Ubuntu system). Such systems run with the root file system in RAM and the device is called cow (which refers to 'copy on write').
A live-only system allocates typically half of the available RAM for the root file system. A persistent live system uses an overlay system, where the partition (or file) for persistence is overlayed on the RAM for the root file system.
Example 1: A live-only system in a computer with 16 GiB RAM
lubuntu@lubuntu:~$ df -h
Filesystem                   Size  Used Avail Use% Mounted on
tmpfs                        1.6G  9.8M  1.6G   1% /run
/dev/sdb1                    1.8G  1.8G     0 100% /cdrom
/cow                         7.8G   17M  7.8G   1% /
/dev/disk/by-label/writable   54G   55M   51G   1% /var/log
tmpfs                        7.8G     0  7.8G   0% /dev/shm
tmpfs                        5.0M  4.0K  5.0M   1% /run/lock
tmpfs                        4.0M     0  4.0M   0% /sys/fs/cgroup
tmpfs                        7.8G     0  7.8G   0% /tmp
tmpfs                        1.6G   80K  1.6G   1% /run/user/999
Example 2: A persistent live system in an SSD with 60 GB connected via USB
tmpfs           1.6G  1.8M  1.6G   1% /run
/dev/sda1       1.8G  1.8G     0 100% /cdrom
/cow             54G   81M   51G   1% /
/dev/sda4        54G   81M   51G   1% /media/lubuntu/writable
You can create both kinds of systems with mkusb
sudodus
  • 47,684
