I am getting the following error:
root@56709:/etc/nginx/conf.d# apt install php7.4-dev
Reading package lists... Done
Building dependency tree
php7.4-dev : Depends: libpcre2-dev (>= 10.30) but it is not going to be installed
Depends: libssl-dev but it is not going to be installed
Depends: php7.4-common (= 7.4.3-4ubuntu2.4) but 7.4.11-6+ubuntu16.04.1+deb.sury.org+1 is to be installed
Recommends: pkg-php-tools but it is not going to be installed
when running apt install php7.4-dev any idea on how to fix it ?
i tried using aptitude instead of apt and here's what i got
root@56709:/etc/nginx/conf.d# sudo aptitude install php7.4-dev
The following NEW packages will be installed:
libpcre2-16-0{a} libpcre2-32-0{a} libpcre2-dev{ab} libpcre2-posix2{a} libssl-dev{ab} php7.4-dev{b} pkg-php-tools{a} shtool{a}
0 packages upgraded, 8 newly installed, 0 to remove and 2 not upgraded.
Need to get 3,295 kB of archives. After unpacking 17.7 MB will be used.
php7.4-dev : Depends: php7.4-common (= 7.4.3-4ubuntu2.4) but 7.4.11-6+ubuntu16.04.1+deb.sury.org+1 is installed
libpcre2-dev : Depends: libpcre2-8-0 (= 10.34-7) but 10.35-5+ubuntu16.04.1+deb.sury.org+1 is installed
libssl-dev : Depends: libssl1.1 (= 1.1.1f-1ubuntu2) but 1.1.1g-1+ubuntu16.04.1+deb.sury.org+1 is installed
The following actions will resolve these dependencies:
Keep the following packages at their current version:
libpcre2-dev [Not Installed]
libssl-dev [Not Installed]
php7.4-dev [Not Installed]
I am currently on ubuntu 20.0.4 but if i see above i think i am still referring to 16.04 .. need to somehow update the sources ?
