I am currently trying to install the following github rpm on my Ubuntu 20 server on AWS.
https://github.com/usrecnik/ddlfs
Currently when I try to install I get an error:
sudo rpm -Uvh https://github.com/usrecnik/ddlfs/releases/download/2.3/ddlfs-2.3.rpm
rpm: RPM should not be used directly install RPM packages, use Alien instead!
rpm: However assuming you know what you are doing...
Retrieving https://github.com/usrecnik/ddlfs/releases/download/2.3/ddlfs-2.3.rpm
error: Failed dependencies:
        fuse is needed by ddlfs-2.3-1.x86_64
        fuse-libs is needed by ddlfs-2.3-1.x86_64
        libaio is needed by ddlfs-2.3-1.x86_64
But when I go to install fuse as an example -- sudo apt-get install -y fuse
It says it is already installed.
How can this be? I have never used a ubuntu server in my life and truly only need it to run this very specific github project. So I am a complete novice. Any advice would make my day. Thank you.
Destx4
RPM (.rpm) packages are made for Red Hat, CentOS and other distributions that use Red Hat Package Manager (RPM).
You should use a DEB (.deb) package if available. DEB packages are made for dpkg and apt which correspond to the package management system used by Debian-based distributions like Ubuntu.
If you really want to install the RPM (not recommeded), please read How do I install and manage RPMs?
Nmath
  • 12,664
