I have written a small Python scraper (using Scrapy framework). The scraper requires a headless browse... I am using ChromeDriver.
As I am running this code on an Ubuntu server which does not have any GUI, I had to install Xvfb in order to run ChromeDriver on my Ubuntu server (I followed this guide)
This is my code:
class MySpider(scrapy.Spider):
name = 'my_spider'
def __init__(self):
# self.driver = webdriver.Chrome(ChromeDriverManager().install())
chrome_options = Options()
chrome_options.add_argument('--headless')
chrome_options.add_argument('--no-sandbox')
chrome_options.add_argument('--disable-dev-shm-usage')
self.driver = webdriver.Chrome('/usr/bin/chromedriver', chrome_options=chrome_options)
I can run the above code from Ubuntu shell and it execute without any errors:
ubuntu@ip-1-2-3-4:~/scrapers/my_scraper$ scrapy crawl my_spider
Now I want to setup a cron job to run the above command everyday:
# m h dom mon dow command
PATH=/usr/local/bin:/home/ubuntu/.local/bin/
05 12 * * * cd /home/ubuntu/scrapers/my_scraper && scrapy crawl my_spider >> /tmp/scraper.log 2>&1
but the crontab job gives me the following error:
Traceback (most recent call last):
File "/home/ubuntu/.local/lib/python3.6/site-packages/scrapy/crawler.py", line 192, in crawl
return self._crawl(crawler, *args, **kwargs)
File "/home/ubuntu/.local/lib/python3.6/site-packages/scrapy/crawler.py", line 196, in _crawl
d = crawler.crawl(*args, **kwargs)
File "/home/ubuntu/.local/lib/python3.6/site-packages/twisted/internet/defer.py", line 1613, in unwindGenerator
return _cancellableInlineCallbacks(gen)
File "/home/ubuntu/.local/lib/python3.6/site-packages/twisted/internet/defer.py", line 1529, in _cancellableInlineCallbacks
_inlineCallbacks(None, g, status)
--- <exception caught here> ---
File "/home/ubuntu/.local/lib/python3.6/site-packages/twisted/internet/defer.py", line 1418, in _inlineCallbacks
result = g.send(result)
File "/home/ubuntu/.local/lib/python3.6/site-packages/scrapy/crawler.py", line 86, in crawl
self.spider = self._create_spider(*args, **kwargs)
File "/home/ubuntu/.local/lib/python3.6/site-packages/scrapy/crawler.py", line 98, in _create_spider
return self.spidercls.from_crawler(self, *args, **kwargs)
File "/home/ubuntu/.local/lib/python3.6/site-packages/scrapy/spiders/__init__.py", line 19, in from_crawler
spider = cls(*args, **kwargs)
File "/home/ubuntu/scrapers/my_scraper/my_scraper/spiders/spider.py", line 27, in __init__
File "/home/ubuntu/.local/lib/python3.6/site-packages/selenium/webdriver/chrome/webdriver.py", line 81, in __init__
desired_capabilities=desired_capabilities)
File "/home/ubuntu/.local/lib/python3.6/site-packages/selenium/webdriver/remote/webdriver.py", line 157, in __init__
self.start_session(capabilities, browser_profile)
File "/home/ubuntu/.local/lib/python3.6/site-packages/selenium/webdriver/remote/webdriver.py", line 252, in start_session
response = self.execute(Command.NEW_SESSION, parameters)
File "/home/ubuntu/.local/lib/python3.6/site-packages/selenium/webdriver/remote/webdriver.py", line 321, in execute
self.error_handler.check_response(response)
File "/home/ubuntu/.local/lib/python3.6/site-packages/selenium/webdriver/remote/errorhandler.py", line 242, in check_response
raise exception_class(message, screen, stacktrace)
selenium.common.exceptions.WebDriverException: Message: unknown error: Chrome failed to start: exited abnormally
(unknown error: DevToolsActivePort file doesn't exist)
(The process started from chrome location /usr/bin/google-chrome is no longer running, so ChromeDriver is assuming that Chrome has crashed.)
(Driver info: chromedriver=2.41.578700 (2f1ed5f9343c13f73144538f15c00b370eda6706),platform=Linux 5.4.0-1029-aws x86_64)
Update
This answer help me solve the issue (but I don't quite understand why)
I ran echo $PATH on my Ubuntu shell and copied the value into the crontab:
PATH=/home/ubuntu/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
Note: As I have created a bounty for this question, I am happy to award it to any answer which explains why changing the PATH solved the issue.
