I am installing Ubuntu 20.04 server via UEFI HTTP booting, subiquity and a NoCloud data source. The actual install works and I get the base OS running.
I also need to configure some things after installation is complete, or on first boot after the installer has rebooted however.
I have tried various things in user-data:
write_files:
- path: /target/etc/example.conf
permissions: 644
content: |
example content
- path: /target/var/lib/cloud/scripts/per-once/test.sh
permissions: 755
content: |
#!/bin/sh
date > /tmp/i_ran
date
echo test1
runcmd:
- echo test2 > /tmp/test2
- cloud-init-per once testing echo test3
- [ cloud-init-per, once, testing2, touch, /tmp/test4 ]
- [ curtin, in-target, --target=/target, --, cloud-init-per, once, testing3, touch, /tmp/testing5 ]
late-commands:
- echo test5 > /target/etc/test5.conf
- curtin in-target --target=/target -- cloud-init-per once testing9 touch /tmp/testing9
The commands run (as seen in the subiquity debug log) but nothing seems to leave a mark on the installed system. e.g. no files in /tmp or /etc and no messages in the post reboot logs that I have found. I have tried write_files with, and without /target before it.
What is the intended method to write arbitrary files on the target or run arbitrary commands after install?
