When trying to upgrade 20.04 to 20.10 using update-manager button Upgrade, I get a message that I must first install all updates. I did sudo apt update + upgrade and I installed all updates suggested by update manager. Now I get no message in the terminal, but nothing happens when I click the button Upgrade or use the command sudo apt -y update && apt -y dist-upgrade. Fyi: I have a triple boot system with Windows 10/Ubuntu LTS 20.04.1 and Ubuntu development version (currently 20.04.1) on tree different partitions (2 hard disks).
Hannie
  • 51
You're on an LTS (long time support) version. There is some safety built in the system that you don't inadvertently upgrade to a non-LTS version.
To overrule this, just for this upgrade, do:
sudo nano /etc/update-manager/release-upgrades
and change Prompt=lts to Prompt=normal.
Then do sudo do-release-upgrade and your upgrade should proceed normally.
Jos
  • 30,529
  • 89
  • 96
This may help.
I had two packages (related to tor) failing install due to an unmet dependancy. (found using sudo apt list --upgradable)
So I removed tor and did the upgrade:
sudo apt remove tor
And then proceeded with the install.
I would reinstall tor after the upgrade.
The lack of error messages was frustrating.
I'm sure it's logged somewhere.
Artur Meinild
  • 31,035
