Took hard drive out of older 386 machine and installed it in newer with AMD FX4300. System will not let me uggrade to latest install due to 386 limitation . How do I fix that and write out the 386 limit?
Ubuntu 18.04 flavors are the last supported releases for x86 (32-bit i686) computers.
your system isn't let you install newer specs OS that has amd64 architecture in i386 compatible hardware due to their addressing capability.
You should try for 18.04 i386 version of Lubuntu for less specs. even computers having 1 GB RAM can run lubuntu smoothly too.
Arbaz
  • 31
