Cannot find netboot mini iso for Ubuntu Groovy 20.10
For the i386 architecture, you can download it here http://archive.ubuntu.com/ubuntu/dists/groovy/main/installer-i386/current/images/netboot/mini.iso
When I click on this link this installation option is displayed http://archive.ubuntu.com/ubuntu/dists/groovy/main/installer-amd64/current/legacy-images/
netinstall
Netbooting the server installer on amd64
Netbooting the live server installer This is now the only option for netinstall Ubuntu Groovy 20.10 amd64?
N0rbert
  • 103,263
Johan Palych
  • 1,401
The Canonical decided to stop providing this image. See these topics on Ubuntu Community and LaunchPad:
As the workaround use 20.04 LTS netboot mini iso from
http://archive.ubuntu.com/ubuntu/dists/focal/main/installer-amd64/current/legacy-images/netboot/
and then upgrade it to groovy by do-release-upgrade after installation.
N0rbert
  • 103,263
There is no mini.iso for Ubuntu 20.10. Not the same, but you can install minimal system using debootstrap. To show this method, I will use Ubuntu 20.10 live iso booted from usb. In terminal:
sudo su -
# Install debootstrap
apt update
apt install debootstrap
Partitioning
fdisk -l mkfs.ext4 /dev/sdaX
mount /dev/sdaX /mnt
Install base packages
debootstrap groovy /mnt
mount /dev /mnt/dev --bind mount /proc /mnt/proc --bind mount /sys /mnt/sys --bind
Go inside new system
chroot /mnt
Install the Linux kernel and text editor
apt update apt install linux-image-generic nano
Check UUID and paste it into /etc/fstab
blkid | grep sdX > /etc/fstab
Edit fstab so it looks like this:
UUID=<your uuid> / ext4 errors=remount-ro 0 1
nano /etc/fstab
Install boot-loader (Legacy BIOS)
On UEFI, change the target to i386-efi
grub-install --target i386-pc /dev/sdX
Optionally, edit grub settings in /etc/default/grub
update-grub
Add user
adduser <name> usermod -aG sudo <name> passwd <name>
Set time and language
dpkg-reconfigure locales dpkg-reconfigure tzdata dpkg-reconfigure keyboard-configuration
Set hostname
nano /etc/hostname
Fix NetworkManager if you install this way: Ethernet device not managed
kamiz
  • 31
Thank you so much for your response!
Read the newsletter Bug 1884538 Re: Removing debian-installer from groovy
Downloaded and installed focal mini.iso
sudo sed -i s/Prompt=lts/Prompt=normal/g /etc/update-manager/release-upgrades
do-release-upgrade -d
uname -a
Linux 5.8.0-25-generic #26-Ubuntu SMP Thu Oct 15 10:30:38 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
And then my choice tasksel
Johan Palych
  • 1,401
