Possible Duplicate:
XAMPP vs. Native LAMP Packages
Looked around for alternatives to WAMP, there seem to be two: lamp-server and XAMPP.
What's the difference between them? Anything in particular to consider before picking one over the other?
Thanks.
Possible Duplicate:
Thanks.
personally I would install phpmyadmin, that will bring in apache and mysql and set it all up for you and give you a nice way to browse the mysql database. You can then put stuff in /var/www/ and it will just work. Look at http://localhost for your stuff and http://localhost/phpmyadmin for the database console. Do remove or secure phpmyadmin if you are putting this on the internet.
LAMP is the most famous solution. Apache is present under 65% of web servers. This is also the easiest and the most documented but not the most efficient. Nginx and Lighttpd are good alternatives.
