Below is an output of df command
# df /boot
Filesystem     1K-blocks   Used     Available Use%  Mounted on
/dev/sda2         122835  26732     89550     23%   /boot
I cannot figure out how the "Available" column is calculated. It doesn't equal:
 1K-blocks - Used
It seems about equal:
(1K-blocks - Used) - ((1K-blocks) * 5 / 100)
My question is, how is the "Available" column calculated?
vho
  • 145
The "Available" column is calculated properly. It shows the available space.
ext4 partitions have 5% reserve by default for root and system services.
You can check that by tune2fs utility.
So it is correct that available space is all space minus used space minus 5%.
Pilot6
  • 92,041
