I have an old Processor Intel® Core™2 CPU T7200 @ 2.00GHz × 2 Why is the current frequency stuck at 1GHZ if the CPU is built for up to 2GHZ?
Here are the frequency #s when I run the following script
root@imparoUbuntu-ThinkPad-T60:~#  paste <(cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_min_freq) <(cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq) <(cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_max_freq) | column -s $'\t' -t
1000000  1000000  2000000
Min Current Max
Also please see "current policy" below:
$ cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  driver: acpi-cpufreq
  CPUs which run at the same hardware frequency: 0
  CPUs which need to have their frequency coordinated by software: 0
  maximum transition latency: 10.0 us.
  hardware limits: 1000 MHz - 2.00 GHz
  available frequency steps: 2.00 GHz, 1.67 GHz, 1.33 GHz, 1000 MHz
  available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil
  **current policy: frequency should be within 1000 MHz and 1000 MHz.**
                  The governor "performance" may decide which speed to use
                  within this range.
  current CPU frequency is 1 GHz.
  cpufreq stats: 2.00 GHz:100.00%, 1.67 GHz:0.00%, 1.33 GHz:0.00%, 1000 MHz:0.00%  (4)
analyzing CPU 1:
  CPUs which run at the same hardware frequency: 1
  CPUs which need to have their frequency coordinated by software: 1
                  within this range.
  cpufreq stats: 2.00 GHz:100.00%, 1.67 GHz:0.00%, 1.33 GHz:0.00%, 1000 MHz:0.00%  (5)
PS: I already changed governor to "performance" but current policy keeps frequency range at 1000 MHZ for both min and max despite the CPU being built for 2Ghz
xiota
  • 5,038
