I am trying to install Slurm-seff Perl package into Ubuntu 19.10.
It has .rpm package to install https://pkgs.org/download/slurm-seff ; but I am unable to install alien to install the .rpm package.
 alien : Depends: debhelper (>= 7) but it is not going to be installed
Also for libslurm-perl and libslurmdb-perl packages:
$ sudo apt-get install libslurm-perl libslurmdb-perl
 libslurm-perl : Depends: perlapi-5.18.2
 libslurmdb-perl : Depends: perlapi-5.18.2
Since it is a perl script I try to run it but unable to make it work from the following approach:
$ git clone https://github.com/SchedMD/slurm.git
$ cd slurm/contribs/seff
$ perl seff
Use of uninitialized value $FindBin::Bin in concatenation (.) or string at seff line 11.
Can't locate Slurmdb.pm in @INC (you may need to install the Slurmdb module) (@INC contains: /../lib/perl /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.28.1 /usr/local/share/perl/5.28.1 /usr/lib/x86_64-linux-gnu/perl5/5.28 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.28 /usr/share/perl/5.28 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at seff line 12.
BEGIN failed--compilation aborted at seff line 12.
Related to this I wasn't able to find any guide.
I am recommended to ask this StackOverflow question in askubuntu.com rather than SO.
Update:
$ sudo apt-get install -f
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libjs-modernizr python3-sip
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
$ dpkg --get-selections | grep hold # returns empty string
$ sudo apt-get update Ign:1 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/4.2 InRelease Ign:2 http://archive.ubuntu.com/ubuntu trusty InRelease Hit:3 http://ppa.launchpad.net/dawidd0811/neofetch/ubuntu eoan InRelease Hit:4 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/4.2 Release Hit:5 http://security.ubuntu.com/ubuntu trusty-security InRelease Hit:6 http://archive.ubuntu.com/ubuntu trusty-updates InRelease Hit:8 http://archive.ubuntu.com/ubuntu trusty-backports InRelease Ign:9 http://archive.ubuntu.com/ubuntu eoan InRelease Hit:10 http://archive.ubuntu.com/ubuntu trusty Release Err:12 http://archive.ubuntu.com/ubuntu eoan Release 404 Not Found [IP: 91.189.88.142 80] Hit:11 http://mirrors.edge.kernel.org/ubuntu xenial InRelease Reading package lists... Done E: The repository 'http://archive.ubuntu.com/ubuntu eoan Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.
$ sudo apt-get autoremove Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Pablo Bianchi
  • 17,371
alper
  • 224
