I want to switch to SSD from HDD. I have dual boot on my hp laptop. My C drive in Windows and Ubuntu / directories have less size than new SSD.
But the whole HDD is of 1 TB and SSD of 240 GB. I am putting my SSD inside laptop using hard disk candy into the CD/DVD slot. And I'm not planning to use the DVD port for DVD again.
How can I clone both systems (only C drive + Ubuntu /) without reinstalling everything if that's possible? I want to use SSD for the operating systems and the old HDD for storage. Noob here. Thanks in advance.
Zanna
  • 72,312
  • Connect both HDD and SSD to the PC.
  • (optional) Boot Windows installation, install drivers for SSD, shutdown.
  • Boot PC from live cd/usb (Ubuntu will be ok).
  • Open gparted. Resize all partitions to smallest possible size, but leave around 100 mb of free space on each one. And move partitions closer to "left border". Apply this operation.
  • Open terminal. Detect which drive is your HDD and which one is SSD (see cat /proc/partitions)
  • sudo dd if=HDD_DEVICE bs=1M of=SSD_DEVICE - it will take some time
    (for example: sudo dd if=/dev/sda bs=1M of=/dev/nvme0n1)
  • sudo partprobe SSD_DEVICE (for example: /dev/nvme0n1)
  • Probably, you'll need to expand partition table and file systems again, so you can use gparted again.
  • Shutdown. Remove HDD.
  • Try to boot again.
Next:
  • If everything looks ok, you can connect HDD, format it, and use as you wish.
  • OR Change UUIDs of HDD file systems: tune2fs /dev/sda1 -U random /dev/sda1 (probably the same for sdb if you have, etc). But don't do this with your SSD!
This operation is potentially dangerous. Be attentive with device names you're using!
