10
I currently have all my websites as directories under /var/www. I would like to set up a virtual host http://foo/ that points to the /var/www/foo/foo directory (and still keep the default localhost behavior).
I added the following file, foo, to /etc/apache2/sites-available/:
<VirtualHost *:80>
    ServerName foo
    DocumentRoot /var/www/foo/foo
    # Other directives here
    <Directory />
        Options FollowSymLinks
        AllowOverride None
    </Directory>
    <Directory /var/www/foo/foo>
        Options Indexes FollowSymLinks MultiViews
        AllowOverride None
        Order allow,deny
        allow from all
    </Directory>
</VirtualHost>
I then ran the following commands:
sudo a2ensite foo
sudo /etc/init.d/apache2 reload
But when I go to http://foo/ it still returns an ISP search page.
Jorge Castro
  • 73,717
Azmisov
  • 243
You need to edit your /etc/hosts file so that http://foo resolves to 127.0.0.1.
Edit the file /etc/hosts (with sudo/root) and add the following line:
127.0.0.1 foo
Simón
  • 463
Dunhamzzz
  • 1,271
Checkout https://github.com/Aslamkv/vh :)
This tool lets you add and remove virtualhost in Ubuntu by doing every configuration for you. It is simple and easy to use.
Disclaimer: I am the author :P
Aslamkv
  • 121
For those using apache. You will need to
Ensure you have .htaccess in root path of the site you are hosting. Example /var/www
Update the /etc/apache2/sites-available/default
From
<Directory /var/www/>
 AllowOverride None
 Order allow,deny
 allow from all
</Directory>
To
 AllowOverride All
 Order allow,deny
 allow from all
</Directory>
Hope this helps someone
thefourtheye
  • 4,922
  • 26
  • 32
If you wish, you can have a look at the answer I've posted here:
https://stackoverflow.com/questions/12532263/apache-domain-for-localhost-to-access-folders-as-http-folder-local/12563570#12563570
