I followed this post here on Ask Ubuntu to install R 4.0, however in the last step
sudo apt install r-base
I get the following error :
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: r-base : Depends: r-base-core (>= 4.0.3-1.1804.0) but it is not going to be installed Depends: r-recommended (= 4.0.3-1.1804.0) but it is not going to be installed Recommends: r-base-html but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I did go down the rabbit hole as someone has mentioned in an answer about this issue and I am still unable to overcome this error.Thanks
Thomas Ward
  • 78,878
The easiest way to fix this is to install aptitude, which will try to resolve the conflict. See that answer to this question answering the held broken packages issue.
Tim B
  • 401
