I'm trying to upgrade from 18.04 to 20.10. My understanding is that I first need to update to 20.04 and then to 20.10. I'm following the instructions on this page.
When I run sudo apt upgrade I get this message:
The following packages have been kept back:
frei0r-plugins libssh-4
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
I have no idea why these are being held back. I vaguely recall installing the first package but don't know what I installed that needed the second package.
When I run sudo apt dist-upgrade I get the same exact message.
When I then proceed to sudo apt do-release-upgrade I get this error:
Checking for a new Ubuntu release
Please install all available updates for your release before upgrading.
Ok, I guess this has something to do with the kept back packages? I read one place that I could unmark them as held, but this doesn't work:
$ sudo apt-mark unhold frei0r-plugins libssh-4
frei0r-plugins was already not hold.
libssh-4 was already not hold.
In another place I read that sudo aptitude safe-upgrade might fix the problem. It installs a few i386 packages but afterwards I still get the same messages/errors as before when I try to upgrade.
I also read that I should run apt list --upgradable and that sudo apt-get install each package listed individually. But when I try that I get this error:
frei0r-plugins : Depends: libopencv-objdetect4.2 but it is not going to be installed
Depends: libopencv-video4.2 but it is not going to be installed
Additionally, when I try to install the second dependency, I says it's going to REMOVE four remmina packages, which I don't want as I use this program quite frequently!
