I have a HP EliteDesk 705 G1 with Ubuntu 2020 and the ethernet connection disconnects after a few minutes using it.
I tried what these other questions suggest with no success.
Machine info:
HP EliteDesk 705 G1 SFF
Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM5762 Gigabit Ethernet PCIe (rev 10)
Any ideas?
Kaz Miller
  • 131
After a deep research my workaround is to add a kernel parameter.
Here's what I did:
  1. Edit file on /etc/default/grub
  2. Add the kernel parameter iommu=pt. Example: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash iommu=pt"
  3. Save file and apply changes with sudo update-grub
  4. Reboot machine.
Hope helps someone.
Kaz Miller
  • 131
great workaround ! It works on my HP Elitedesk 705 G1 SFF Linux Mint 19.3 as well.
Network:   Device-1: Broadcom and subsidiaries NetXtreme BCM5762 Gigabit Ethernet PCIe
       vendor: Hewlett-Packard driver: tg3 v: 3.137 port: f100 bus ID: 03:00.0
       chip ID: 14e4:1687
       IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
You made my day, now I can finally get rid of my USB-Ethernet adaptor. ! Thanks !
Workaround worked for one hour or so, and suddenly stopped. "No connection" - "Cable unplugged", which isn't the case. Rebooting the workstation fixes this issue. So small improvement (at least it works for a while), but no stable solution yet.
