I searched this online but all articles found are outdated. What should I do to enable hibernation in GNOME?
To enable Hibernation in 20.04:
Increase swapfile size to match RAM size up to 8GB.
  • Check the swap that is in use:
    sudo swapon -s
  • If swap partition(s) found:
    sudo swapoff -a
    sudo nano -Bw /etc/fstab
  • Add "# " before the UUID of the swap partition(s):
    # UUID=XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX none swap sw 0 0
  • Add a line for the swapfile, if one does not exist:
    swapfile none swap sw 0 0
  • Create the swap file:
    sudo fallocate -l XG /swapfile*
Where X is the swapfile size in GB
    sudo mkswap /swapfile
sudo chmod 0600 /swapfile
sudo swapon /swapfile
  • Reboot:
    sudo reboot
Add resume location and offset to grub.cfg:
  • Edit /etc/default/grub:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX resume_offset=XXXXX"
  • Use UUID from root.
  • Use offset from sudo filefrag -v /swapfile |grep " 0:"| awk '{print $4}'
  • Update GRUB sudo update-grub
  • Test hibernation sudo systemctl hibernate
A hibernate button can be added using gnome extensions. https://extensions.gnome.org/extension/755/hibernate-status-button/
*There is a slight possibility of getting holes in a swapfile when creating it with fallocate. /var/log/syslog can be searched for the phrase swapon: swapfile has holes to ensure there will be no data loss.
A swapfile can alternatively be created using dd: sudo dd if=/dev/zero of=/swapfile bs=1G count=8 An error when using dd may overwrite your HDD
C.S.Cameron
  • 20,530
  • 78
  • 125
