I'm tryning to install Ubuntu 20.04 LTS on a micro SD Card as described above. But I am getting this error message:
XDG_URNTIME_DIR (/run/user/999) is owned by us (uid 0), but by uid 999! (This could e.g. happen if you try to connect to a non-root PulseAudio as a root user, over the native protocol. Don't to that.)
Also the benchmark of the disk is not delivering the desired Read/Write rate, being around 17/8 MBs R/W, I would like to know if this is a physical limitation of the card reader, a drive or Bios energy device control problem, like acpi or a problem with the card meaning it's damaged or not being an original sandisk.
Creating a Full install Ubuntu SD card from a Pre-built Image File.
If working in Windows:
(Password is "changeme", change it),
The SD card should boot on almost any modern X86-64 computer.
Thanks to sudodus for the image file.
In Windows it may be necessary to install 7Zip before proceeding. Rufus will use it when working with the .xz image: https://www.7-zip.org/a/7z1900-x64.exe
If working in Ubuntu: you can use mkusb, Disks or Etcher to flash the SD card. P7zzip may be needed to extract the image.
C.S.Cameron
  • 20,530
  • 78
  • 125
