My Intel WiFi AX200 - MSI X570 wireless network adapter recently stopped working. I'm running Ubuntu 20.04.
uname -a; dmesg | grep iwl
Linux adrian-MS-7B93 5.4.0-51-generic #56-Ubuntu SMP Mon Oct 5 14:28:49 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
[ 3.526169] iwlwifi 0000:28:00.0: enabling device (0000 -> 0002)
[ 3.648129] iwlwifi: probe of 0000:28:00.0 failed with error -110
sudo lshw -C network
*-network
description: Ethernet interface
product: I211 Gigabit Network Connection
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:26:00.0
logical name: enp38s0
version: 03
serial: 00:d8:61:bc:3a:68
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi msix pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=igb driverversion=5.6.0-k duplex=full firmware=0. 6-2 ip=192.168.1.17 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:24 memory:fc600000-fc61ffff ioport:d000(size=32) memory:fc620000-fc623fff
*-network UNCLAIMED
description: Network controller
product: Wi-Fi 6 AX200
physical id: 0
bus info: pci@0000:28:00.0
version: 1a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: memory:fc500000-fc503fff
I tried adding the IntelĀ® Wi-Fi 6 AX200 160MHz .ucode firmware file to /lib/firmware from Intel's website with no luck.
I also tried a fresh 20.04 installation. One common item between others that I see having this issue is that they also dual boot Windows. The weird thing is I used Ubuntu 20.04 for 3+ months, and then swapped back to Windows for a few days, and upon booting back up in Ubuntu it no longer works. Switched back to Windows again to verify that the device actually works, which it still does.
