After installing Python3.7, the software-properties-gtk is not opening. When calling it from terminal, the following error is shown:
ERROR:dbus.proxies:Introspect error on :1.171:/: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
Traceback (most recent call last):
File "/usr/bin/software-properties-gtk", line 100, in <module>
app = SoftwarePropertiesGtk(datadir=options.data_dir, options=options, file=file)
File "/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py", line 173, in __init__
self.backend.Reload();
File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 70, in __call__
return self._proxy_method(*args, **keywords)
File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 145, in __call__
**keywords)
File "/usr/lib/python3/dist-packages/dbus/connection.py", line 651, in call_blocking
message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.ServiceUnknown: The name :1.171 was not provided by any .service files
I am running UBUNTU 18.04. I checked this post, but all answers were not working. I hope someone came by this problem and was able to solve it. Thanks
Edit: Upon request, here is the command output:
#which python; ls -l $(which python); echo =; which python3; ls -l $(which python3)
/usr/bin/python
lrwxrwxrwx 1 root root 24 Nov 4 20:51 /usr/bin/python -> /etc/alternatives/python
/usr/bin/python3
lrwxrwxrwx 1 root root 25 Nov 4 20:54 /usr/bin/python3 -> /etc/alternatives/python3
Another debugging request
#ls -al /usr/bin/ | grep python
lrwxrwxrwx 1 root root 26 Mar 26 2018 dh_pypy -> ../share/dh-python/dh_pypy
-rwxr-xr-x 1 root root 1056 Apr 16 2018 dh_python2
lrwxrwxrwx 1 root root 29 Mar 26 2018 dh_python3 -> ../share/dh-python/dh_python3
lrwxrwxrwx 1 root root 23 Sep 30 15:38 pdb2.7 -> ../lib/python2.7/pdb.py
lrwxrwxrwx 1 root root 23 Oct 8 14:12 pdb3.6 -> ../lib/python3.6/pdb.py
lrwxrwxrwx 1 root root 23 Aug 18 08:22 pdb3.7 -> ../lib/python3.7/pdb.py
lrwxrwxrwx 1 root root 31 Oct 25 2018 py3versions -> ../share/python3/py3versions.py
lrwxrwxrwx 1 root root 26 Mar 26 2018 pybuild -> ../share/dh-python/pybuild
lrwxrwxrwx 1 root root 9 Apr 16 2018 python -> python2.7
lrwxrwxrwx 1 root root 9 Apr 16 2018 python2 -> python2.7
-rwxr-xr-x 1 root root 3628976 Sep 30 15:38 python2.7
lrwxrwxrwx 1 root root 25 Nov 6 13:38 python3 -> /etc/alternatives/python3
-rwxr-xr-x 2 root root 4526456 Oct 8 14:12 python3.6
lrwxrwxrwx 1 root root 33 Oct 8 14:12 python3.6-config -> x86_64-linux-gnu-python3.6-config
-rwxr-xr-x 2 root root 4526456 Oct 8 14:12 python3.6m
lrwxrwxrwx 1 root root 34 Oct 8 14:12 python3.6m-config -> x86_64-linux-gnu-python3.6m-config
-rwxr-xr-x 2 root root 5316432 Aug 18 08:22 python3.7
-rwxr-xr-x 2 root root 5316432 Aug 18 08:22 python3.7m
lrwxrwxrwx 1 root root 16 Oct 25 2018 python3-config -> python3.6-config
lrwxrwxrwx 1 root root 10 Oct 25 2018 python3m -> python3.6m
lrwxrwxrwx 1 root root 17 Oct 25 2018 python3m-config -> python3.6m-config
lrwxrwxrwx 1 root root 29 Apr 16 2018 pyversions -> ../share/python/pyversions.py
lrwxrwxrwx 1 root root 34 Oct 8 14:12 x86_64-linux-gnu-python3.6-config -> x86_64-linux-gnu-python3.6m-config
-rwxr-xr-x 1 root root 3283 Oct 8 14:12 x86_64-linux-gnu-python3.6m-config
lrwxrwxrwx 1 root root 33 Oct 25 2018 x86_64-linux-gnu-python3-config -> x86_64-linux-gnu-python3.6-config
lrwxrwxrwx 1 root root 34 Oct 25 2018 x86_64-linux-gnu-python3m-config -> x86_64-linux-gnu-python3.6m-config
#readlink -f /usr/bin/python
/usr/bin/python2.7
#ls -al /usr/bin/ | grep python3
DBUS service check
#systemctl status dbus.service
● dbus.service - D-Bus System Message Bus
Loaded: loaded (/lib/systemd/system/dbus.service; static; vendor preset: enabled)
Active: active (running) since Sun 2020-11-08 12:40:49 EET; 1h 22min ago
Docs: man:dbus-daemon(1)
Main PID: 763 (dbus-daemon)
Tasks: 3 (limit: 4915)
CGroup: /system.slice/dbus.service
├─ 763 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
└─13887 /usr/bin/python3 /usr/share/usb-creator/usb-creator-helper
Nov 08 13:51:00 TTS-UBUNTU dbus-daemon[763]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 08 13:51:00 TTS-UBUNTU dbus-daemon[763]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 08 13:52:18 TTS-UBUNTU dbus-daemon[763]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 08 13:52:18 TTS-UBUNTU dbus-daemon[763]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 08 13:52:58 TTS-UBUNTU dbus-daemon[763]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 08 13:52:58 TTS-UBUNTU dbus-daemon[763]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 08 13:57:39 TTS-UBUNTU dbus-daemon[763]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 08 13:57:39 TTS-UBUNTU dbus-daemon[763]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 08 13:58:19 TTS-UBUNTU dbus-daemon[763]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 08 13:58:19 TTS-UBUNTU dbus-daemon[763]: [system] Successfully activated service 'org.freedesktop.hostname1'
