11
I have installed Sql Server 2019 Developer Edition and mssql-tools on my Ubuntu 20.04 minimal. I can connect to my localhost with no issue, but when I want to remote to another sql server:
sqlcmd -S <server> -U <username> -P <password>
I face this error:
Sqlcmd: Error: Microsoft ODBC Driver 17 for SQL Server : SSL Provider: [error:1425F102:SSL routines:ssl_choose_client_version:unsupported protocol].
Sqlcmd: Error: Microsoft ODBC Driver 17 for SQL Server : Client unable to establish connection.
I has this issue once in Debian 10, and also search the net for solution, so after that I change my openssl.conf manually (su permission needed):
nano /etc/ssl/openssl.cnf
and add these to my file:
  • ess_cert_id_alg = sha1 under the [tsa_config1] heading
  • openssl_conf = default_conf near the top
  • the following at the end:
    [default_conf]
    ssl_conf = ssl_sect
    [ssl_sect]
    system_default = system_default_sect
    [system_default_sect]
    MinProtocol = TLSv1.0
    CipherString = DEFAULT@SECLEVEL=1
I know that MinProtocol and CipherString are normally set to TLSv1.2 and DEFAULT@SECLEVEL=2, but as I mentioned once in my Debian 10, I edited my openssl.conf and change TLSv1.2 to TLSv1.0 and DEFAULT@SECLEVEL=2 to DEFAULT@SECLEVEL=1 and my connection fixed, but in Ubuntu 20.04 minimal not only there wasn't these lines, but also when I insert these manually again I face the same error:
my opnessl version is:
OpenSSL 1.1.1f  31 Mar 2020
I also downgrade my openssl once to 1.0 but it didn't work either!
I couldn't find anything else so I came here to ask for help, appreciate your help.
Amirali Samiei
  • 223
The reason might be that your current openssl doesn't support / turned off some ciphers (supported by your previous installation) and the server requires them. Just compare output:
nmap --script ssl-enum-ciphers localhost
nmap --script ssl-enum-ciphers <DB SERVER IP>
Solution: try to install a new version of openssl (>1.1.1f) manually. I upgraded from 1.1.1f to 1.1.1p and it solved my problems, no extra configuration required. I also read similar cases with 18.04 -> 20.04 and 1.1.1f which affected other guys.
The manual installation looks like:
wget https://www.openssl.org/source/openssl-1.1.1p.tar.gz -O openssl-1.1.1p.tar.gz
tar -zxvf openssl-1.1.1p.tar.gz
cd openssl-1.1.1p
./config
make
sudo make install
sudo ldconfig
openssl version
Note: You can also avoid the first line above and manually download the source tar.gz by going to their download page.
Hope, this will help
Note if after the download and tar un-compress the directory is something like openssl-3.0.0 then change to that directory instead, run the steps above, but if openssl version fails with an error
error while loading shared libraries: libssl.so.3: cannot open shared object file: No such file or directory
you need to copy a few more files:
sudo cp /usr/local/lib64/libcrypto.so.3 /usr/lib
sudo cp /usr/local/lib64/libssl.so.3 /usr/lib
sudo cp /usr/local/lib64/libssl.so /usr/lib
and finally, update the dynamic linker's links and cache:
sudo ldconfig
jan-seins
  • 145
nordborn
  • 251
It's 2025, march and I have been struggling with this issue for weeks now.I was getting this error:
ubuntu_sql_client | Failed to connect: ('08001', '[08001] [Microsoft][ODBC Driver 17 for SQL Server]SSL Provider: [error:1425F102:SSL routines:ssl_choose_client_version:unsupported protocol] (-1)
In my case, I was trying to connect a django app to sql server from docker. Django is running inside docker container, sql server is running on a VM on the network.
Here's the set up that worked for me:
Dockerfile
FROM ubuntu:22.04
Set non-interactive mode to avoid prompts
ENV DEBIAN_FRONTEND=noninteractive
Install dependencies and ODBC driver
RUN apt update && apt install -y curl gnupg2 apt-transport-https software-properties-common wget build-essential &&
curl https://packages.microsoft.com/keys/microsoft.asc | apt-key add - &&
add-apt-repository "$(curl -fsSL https://packages.microsoft.com/config/ubuntu/22.04/prod.list)" &&
apt update &&
ACCEPT_EULA=Y apt install -y msodbcsql17 unixodbc unixodbc-dev &&
apt clean && rm -rf /var/lib/apt/lists/*
Install Python and pip
RUN apt update && apt install -y python3 python3-pip && pip3 install --no-cache-dir pyodbc
RUN ln -s /usr/bin/python3 /usr/bin/python
Upgrade OpenSSL
RUN wget https://www.openssl.org/source/openssl-1.1.1p.tar.gz -O openssl-1.1.1p.tar.gz &&
tar -zxvf openssl-1.1.1p.tar.gz &&
cd openssl-1.1.1p &&
./config &&
make -j$(nproc) &&
make install &&
ldconfig &&
openssl version
Install weasyprint dependencies
RUN apt-get update && apt-get install -y libcairo2 libgdk-pixbuf2.0-0 libpango-1.0-0 libpangoft2-1.0-0
Set environment variables for ODBC
ENV ODBCINI=/etc/odbc.ini ENV ODBCSYSINI=/etc
Set working directory
WORKDIR /app
COPY requirements.txt /app/ RUN pip install --upgrade pip RUN pip install -r /app/requirements.txt
COPY ./cont_configs/openssl.cnf /etc/ssl/openssl.cnf
COPY . /app
EXPOSE 8000
RUN chmod +x ./entrypoint.sh CMD [ "./entrypoint.sh" ]
Note that the default openssl that comes with ubuntu 22.04 is downgraded and /etc/ssl/openssl.cnf updated after installing other dependencies.
In the /etc/ssl/openssl.cnf I added this at the top
and these at the bottom
[default_conf]
ssl_conf = ssl_sect
[ssl_sect] system_default = system_default_sect
[system_default_sect] MinProtocol = TLSv1 CipherString = DEFAULT:@SECLEVEL=0
[openssl_init] providers = provider_sect
Mind you this is a project I'm still developing so I continue to experiment and make the code better. But the dockerfile and openssl.cnf code shared for now works like a charm.
