[EDIT] After spending an unscrupulous amount of time draftiving, revising, finding references, citations, and posting this answer, I'm embarassed to say the least that the OP had already answered their own question. My initial thought was to delete my answer as most of it is irrelevant but that remains difficult after the amount of time invested into what may amount to nothing. Though I hope to address the newly discovered issue mentioned in the OP's unmarked answer.
Updated issue:
Using a loopback device with the right offset does allow mounting and
access of the partitions --- though I still seem to be unable to
access the LUKS sdb5 partition (since it isn't reported), even when I
put in the address calculated from the offset on the original drive.
The data's there, but the screwy reporting keeps cryptsetup from
working. Not sure if there is a workaround other than getting a less
presumptuous usb chassis.
Since it seems to work while connected internally and you've determined the issue is the chassis, why not just recopy the drive and change your bs value? After all, when you plugged the original drive in through the chassis, you were able to access files, so it was recognized in that way. So it's odd that the original drive could be read through the chassis but not the new copy unless...
...By chance part my answer did happen to apply. Then perhaps with the loop device scenario whereby you calculated the offset from the original drive, you can try this script to determine the offset being reported when it's connected as USB to address the partition not being recognized.
Otherwise the more simple but more tedious fix would be to reformat the spare drive prior to recopying the main drive to back it up so that when it's plugged in as an externa USB device, the chipset doesn't get confused and cause linux to convert an incorrect byte offset.
[END EDIT]
The Old and Inapplicable Oversimplified Explanation
What's happening is that you probably didn't format the spare disk you found before using dd to backup your main linux install and what you had on your main linux install hard drive was an MBR partition scheme while the spare disk had a GPT partition scheme.
@oldfred pointed this out in a comment already but no response to the request for output of the following command has still not yet been received
sudo gdisk -l /dev/sdb
(whereas I've replaced the X to represent how the disk is shown in reference for the GPT/MBR related error, AKA the laptop)
So when you used dd to copy the entire disk onto the the spare disk, which is larger than the original (or source) disk, and since it does, in fact, copy byte for byte of the drive, it copied over the partition scheme (including the partition table and headers) of the former hard disk and laid it on top of the GPT partition scheme of the larger disk.
This means it would've been blocked by GPT's protective MBR layer which is designed to prevent MBR-based disk utilities from misrecognizing and possibly overwriting a GPT disks and conflicted with the LUKS header which sits at the start of the device, in the same place the Protective MBR sits. So when it was not allowed to write this part, it was not able to include the proper header information for /dev/sdb5 or /dev/sda5 whichever the case may be.
And, if you're wondering why dd didn't report any of this as an error or run with that 'complaint' when it finished, this might be why I wouldn't be able to tell you without the ouput shown by dd when it finished, which usually looks something like this:
6+1 records in
6+1 records out
3454 bytes (3.5 kB) copied, 8.3585e-05 s, 41.3 MB/s
But otherwise if it had mentioned it, it would've been reported in real time and not shown at the end. Otherwise you'd probably have to look in your kernel log messages (dmesg, or /var/log/kern.log) for more detailed messages in case it would've been considered a hardware error. You may also find smartctl -x /dev/sda useful in this case since it would've been something to write to a section prior to the beginning a partition or something, which might also show up in the kernel log. Especially since this error wasn't reported until afterwards:
Found invalid GPT and valid MBR; converting MBR to GPT format in
memory.
With how complicated this "oversimplified answer" is getting, I digress and won't bother getting into the specific conflicts of how it all works with MBR Disk partitioning versus GPT partition table headers and GPT partition entries and how that is affected by BIOS, UEFI, or UEFI with CSM conditions, to further perhaps unnecessarily the "why" as that might be beyond the scope of how to resolve your issue but hopefully offered some level of insight.
To address this in the future you can check the backup image consistency for any problems with the backup copy prior to all the trouble of connecting to the laptop
fsck -y /dev/sdb
Which reminds me, when dd completed "without complaint", was the live boot stick system able to see the third partition?? Because if it could, was there any attempt to access your data from there? If yes to both, then that might invalidate everything I just thought whereby your hard drive enclosure's controller might be the suspect.
Ahh well...
Moving Forward - Backup of your data
Depending on what your ultimate goal is, whether it is:
- To make a backup of your just your data so that it's not lost
while trying to fix your main PC where you can just copy that data
back into the PC once it's fixed; or
- if it's to create an exact duplicate of your main PC so that if you
mess up any attempt to fix the "broken install" you can start over
from the beginning
Then how you may want to proceed will vary. The main difference that is inferred and/or needs to be assumed here is that for each scenario from above, then respectively, in the case of:
- If all else fails, you would have to resort to a fresh install of your desired operating system and copy over your data by mounting it as an external or internal drive and would be limited to personal files so any apps, packages, programs or settings would need to be redownload, reinstalled; or reset while (More Work - File Data exclusive restoration)
- If all else fails, you can keep trying and start over from where you are now, so that you can get your system back to boot without needing to reinstall anything or copying over anything (More tries - Full system restoration)
Since you mentioned that you're "hesitant to do anything until [you've] ascertained [you] can access [your] data on [your] back up disk", I will assume you just want to have a backup of your data as you go about fixing your PC and assume that your extended partition mentioned in the output of fdisk as /dev/sda2 doesn't contain any desirable data to be preserved and that only /dev/sda5 is relevant since it was mentioned
...but without /dev/sdb5 I can't mount the LUKS encrypted volume and I
can't access my data.
Then I would suggest that you change your options and flags for dd so that rather than make a backup of your entire disk by copying it directly to the spare disk, you instead either make a backup image copy of the entire disk by changing the of of dd to point to an image file saved onto your mounted spare disk, whereby you can then mount that image virtually either as a virtual system so that you avoid any partitioning conflicts on the spare drive or even better yet, change the if flag of dd and copy only the partition you need which would be /dev/sda5 if using the naming schemes referenced when mounting both disks and booting from a live stick system.
Since you refrained from using the oflag=direct or oflag=sync options when copying the disks, I strongly suggest you review the dd man page for options if doing the above.
Addressing Your Questions
My understanding is that dd copies every byte, and there's no hidden
metadata it misses, but I'm not an expert on modern disk controllers.
Am I missing something (other than /dev/sdb5)?
Yes you're right, but as we've discovered, minor write errors could've been overlooked without proper logging in terms of the hidden metadata. Because it read it fine, it just couldn't write it. So, while it's difficult to quantify what you're missing as it already seems like you know quite a bit, I would, at the least, simply mention dd does makes a copy of every bit, byte for byte, and it would go so far as to even copy the empty spaces or NULL bytes of unpartitioned space and even unmarked "empty space" where files once existed but were deleted and could be recovered therefore could be recovered if a copy using 'dd' included that "empty space". But it does a lot more than simply read from stdin and output to stdout albeit it takes incorporating some options, but I digress.
If anything, I would venture to say that something most people perhaps often forget to consider is what copying every byte actually means or translates to, depending on the scenario and what's being copied/read from or what medium holding the data is used, such as a device that is not similar in size or type to the source being copied. One specific reference to elaborate on this would be that if it can't be read by dd it can't be written to by dd. So in terms of copying a filesystem from one drive to one that is nearly or exactly similar, some hardware level coded data won't be carried over and bits of information that is relied on for hardware addressing by other data not stored in the file or device itself and the such won't be changed. But for some, that's obvious while for others it's not. To be sure, if it exists on a block and can be read by the computer but is not revealed to the user, it can be copied.
Is there something I need to do on the laptop? The passphrase should
be the same if it is a true byte-clone of the original.
As we've surmised by now, it's not the laptop causing the issue but the exact duplication of data on to mismatched hardware and mismatched partition schemes (but more so the latter as will later be explained), that resulted in a partition that can't be recognized by the OS and thus resulted in an inability to mount. As for the passphrase being the same, yes you're right, it is the same.
To take it a step further, as noted in the LUKS faqs under 1.2 Warnings - Cloning/Imaging:
If you clone or image a LUKS container, you make a copy of the LUKS
header and the master key will stay the same! That means that if you
distribute an image to several machines, the same master key will be
used on all of them, regardless of whether you change the passphrases.
yes you're right, it is the same. but you're issue is not that it's not recognizing the password, but the partition itself.
More Elaborate Explanation (without getting too technical)
While the mismatched partition schemes are the named suspects of the issue as a result examining the error message provided, the conclusion stemmed from a number of experiences that have been presumed to apply but details pertaining to them were omitted likely due to their seemingly unrelated involvement in creating the issue. These considerations included:
- Knowing the partition scheme of the main linux system SSD which was determined as having an MBR partition scheme since it was mentioned that
/dev/sda2 was an extended partition and those only exist in MBR. The missing piece for solid conclusive evidence is whether the PC was running in BIOS/Legacy or UEFI with CSM support
- Without knowing the motherboard settings for BIO or UEFI, we don't know if the live boot stick was launched in legacy or UEFI mode but it had to match the desktop in being able to recognize both disks when attached. Though suffice to say, we don't have what was defined as "being recognized" since to make a proper copy with
dd for every byte for byte would've required offline copies, meaning you wouldn't have mounted them to see if you could actually access them. But we dont know what system was used to make the copy either or what version of dd was used
- Knowing for certain the partition scheme of the spare hard drive - there isn't much information on the spare drive's origins, what format it was in, where it came from (if it was a Linux PC or Windows PC) which would've greatly help determine the destination of the data being written where errors were found
- Finally, we knew the laptop could see the drive before the backup was made so it had to have CSM support if running UEFI or booted in BIOS mode. When it was able to access the first 2 partitions of the backup but not see the 3rd luks encrypted partition, it stands to reason it was not at all having to do with OS system recognition but missing partition header information causing the unviewable drive.
Additional Notes & Considerations
Some trivial notations to help you more efficiently get help or find answers in the future, feel free to take it or leave it as I only offer them as suggestions and not as any sort of criticism or ridicule since I'm sure anyone can equally point out mistakes of mine from this post as well (and means to say I am no better than you), with all due respect:
- In case it is not already know, "Partition" and "Volume" are not usually interchangeable and technically refer to different units of storage of a hard drive. Whereas a volume is a single accessible storage area with a single file system. A partition is a logical division of a hard disk. Although it might be just semantics for this post, it may help cause less misinterpretation in other scenarios when trying to understand the events that take place
- Please try to be consistent with your references, you show an
fdisk output indicating /dev/sda1 /dev/sda2 and /dev/sda5 but then refer to using cryptsetup on /dev/s**d**b5 I understand the device location changes with each system but it can create confusion to what you're trying specifically, such as the what, when, and where. i.e. Seeing as how fdisk shows partitions for /dev/sda from context I can assume this was run on the laptop, and when you mention the dd command, judging by the input flag (or if=) I can assume it's the source disk, but if I assume based on the information provided that cryptsetup was run on the same drive as the same one referred to in fdisk and dd then it must be on a different system to have a different device assignment. Conversely, if I assume it was the laptop, then I must assume some sort of swapping took place to constitute being the same drive or it's not the same device to receive a device mapping name change. Though in this case it may not be as pertinent, in other cases it might mean one error over another.
- With consideration of the 2 aforementioned points above, it might be more clear how increasingly confusing it is when you mention the source disk being a 1.8 TB SSD and the destination being a 3TB HDD but then you go on to show the
gdisk output for a 5TB disk which suggests either there was a typo in referencing a 3 TB disk or you meant to say a 3TB partition of an HDD whereas the latter would help point out an issue resulting from command option flag being executed as opposed to something else.
- Though you've mentioned "I doubt it matters," there is quite a bit of significance in the size and drive type when using
dd with regard to making backups. Especially if it's important data not to be thought of as nuance, then it's good to note those things as I would've brought up the issues that would've contributed to possible errors not otherwise reported after using dd (such as ones only reported in dmesg from bufferbloat) had it not been the case as prescribed here and more specific to when you transfer from a lower capacity drive to a higher capacity drive as well as a solid state drive to a hard disk drive in terms of effective options to be used with dd to mitigate performance issues, cache errors, and ultimately reliability of the data being transferred. (Though I've deleted the original summary of how that all matters since it wouldn't help resolve your issue anyway)
