I am trying to install zathura, and this operation has worked fine for me on the Windows WSL2 Ubuntu-18.04. However, when I installed Ubuntu-20.04 in its stead, I keep getting errors like these which say that a very specific subset of packages are missing? Can someone explain if this is an error on the WSL2 side or the Ubuntu side and what I need to do to fix this? Otherwise I suppose I could just downgrade to 18.04.
I have also done sudo apt update and sudo apt upgrade and related operations before doing this, to no avail.
me:~$ sudo apt install zathura
Reading package lists... Done
Building dependency tree
zathura is already the newest version (0.4.5-2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
26 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up dictionaries-common (1.28.1) ...
Install emacsen-common for emacs
emacsen-common: Handling install of emacsen flavor emacs
/usr/lib/emacsen-common/packages/install/emacsen-common: 17: emacs: not found
ERROR: install script from emacsen-common package failed
dpkg: error processing package dictionaries-common (--configure):
installed dictionaries-common package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of aspell-en:
aspell-en depends on dictionaries-common (>= 0.49.2); however:
Package dictionaries-common is not configured yet.
dpkg: error processing package aspell-en (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of aspell:
aspell depends on dictionaries-common (>> 0.40); however:
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: error processing package aspell (--configure):
dpkg: dependency problems prevent configuration of hunspell-en-us:
hunspell-en-us depends on dictionaries-common (>= 0.10); however:
dpkg: error processing package hunspell-en-us (--configure):
dpkg: dependency problems prevent configuration of libenchant-2-2:amd64:
libenchant-2-2:amd64 depends on hunspell-en-us | hunspell-dictionary | myspell-dictionary | aspell-dictionary | ispell-dictionary; however:
Package hunspell-en-us is not configured yet.
Package hunspell-dictionary is not installed.
Package hunspell-en-us which provides hunspell-dictionary is not configured yet.
Package myspell-dictionary is not installed.
Package aspell-dictionary is not installed.
Package aspell-en which provides aspell-dictionary is not configured yet.
Package ispell-dictionNo apport report written because MaxReports is reached already
dpkg: error processing package libenchant-2-2:amd64 (--configure):
dpkg: dependency problems prevent configuration of libenchant1c2a:amd64:
libenchant1c2a:amd64 depends on hunspell-en-us | hunspell-dictionary | aspell-dictionary | myspell-dictionary | ispell-dictionary; however:
Package ispell-dictionary is not installed.
dpkg: error processing package libenchant1c2a:amd64 (--configure):
dpkg: dependency problems prevent configuration of enchant-2:
enchant-2 depends on libenchant-2-2 (>= 2.2.3); however:
Package libenchant-2-2:amd64 is not configured yet.
dpkg: error processing package enchant-2 (--configure):
dpkg: dependency problems prevent configuration of enchant:
enchant depends on libenchant1c2a (>= 1.6.0); however:
Package libenchant1c2a:amd64 is not configured yet.
dpkg: error processing package enchant (--configure):
dpkg: dependency problems prevent configuration of libwebkit2gtk-4.0-37:amd64:
libwebkit2gtk-4.0-37:amd64 depends on libenchant-2-2 (>= 2.2.3); however:
dpkg: error processing package libwebkit2gtk-4.0-37:amd64 (--configure):
dpkg: dependency problems prevent configuration of libgoa-backend-1.0-1:amd64:
libgoa-backend-1.0-1:amd64 depends on libwebkit2gtk-4.0-37 (>= 2.21.1); however:
Package libwebkit2gtk-4.0-37:amd64 is not configured yet.
dpkg: error processing package libgoa-backend-1.0-1:amd64 (--configure):
dpkg: dependency problems prevent configuration of gir1.2-webkit2-4.0:amd64:
gir1.2-webkit2-4.0:amd64 depends on libwebkit2gtk-4.0-37 (>= 2.27.90); however:
dpkg: error processing package gir1.2-webkit2-4.0:amd64 (--configure):
dpkg: dependency problems prevent configuration of gnome-control-center:
gnome-control-center depends on libgoa-backend-1.0-1 (>= 3.10.0); however:
Package libgoa-backend-1.0-1:amd64 is not configured yet.
dpkg: error processing package gnome-control-center (--configure):
dpkg: dependency problems prevent configuration of gnome-online-accounts:
gnome-online-accounts depends on libgoa-backend-1.0-1 (= 3.36.0-1ubuntu1); however:
gnome-online-accounts depends on libwebkit2gtk-4.0-37 (>= 2.12.0); however:
dpkg: error processing package gnome-online-accounts (--configure):
dpkg: dependency problems prevent configuration of libedataserverui-1.2-2:amd64:
libedataserverui-1.2-2:amd64 depends on libwebkit2gtk-4.0-37 (>= 2.15.1); however:
Package libNo apport report written because MaxReports is reached already
dpkg: error processing package libedataserverui-1.2-2:amd64 (--configure):
dpkg: dependency problems prevent configuration of yelp:
yelp depends on libwebkit2gtk-4.0-37 (>= 2.19.2); however:
dpkg: error processing package yelp (--configure):
dpkg: dependency problems prevent configuration of libyelp0:amd64:
libyelp0:amd64 depends on libwebkit2gtk-4.0-37 (>= 2.19.2); however:
dpkg: error processing package libyelp0:amd64 (--configure):
dpkg: dependency problems prevent configuration of zenity:
zenity depends on libwebkit2gtk-4.0-37 (>= 2.15.1); however:
dpkg: error processing No apport report written because MaxReports is reached already
package zenity (--configure):
dpkg: dependency problems prevent configuration of libwebkit2gtk-4.0-dev:amd64:
libwebkit2gtk-4.0-dev:amd64 depends on libwebkit2gtk-4.0-37 (= 2.28.4-0ubuntu0.20.04.1); however:
libwebkit2gtk-4.0-dev:amd64 depends on gir1.2-webkit2-4.0 (= 2.28.4-0ubuntu0.20.04.1); however:
Package gir1.2-webkit2-4.0:amd64 is not configured yet.
dpkg: error processing package libwebkit2gtk-4.0-dev:amd64 (--configure):
dpkg: dependency problems prevent configuration of mutter:
mutter depends on zenity; however:
Package zenity is not configured yet.
dpkg: error processing package mutter (--configure):
dpkg: dependency problems prevent configuration of gnome-shell:
gnome-shell depends on mutter (>= 3.36.0); however:
Package mutter is not confiNo apport report written because MaxReports is reached already
gured yet.
dpkg: error processing package gnome-shell (--configure):
dpkg: dependency problems prevent configuration of ubuntu-session:
ubuntu-session depends on gnome-shell (>= 3.36.0-2ubuntu1~); however:
Package gnome-shell is not configured yet.
dpkg: error processing package ubuntu-session (--configure):
dpkg: dependency problems prevent configuration of gdm3:
gdm3 depends on gnome-shell (>= 3.19.92); however:
dpkg: error processing package gdm3 (--configure):
dpkg: dependency problems prevent configuration of ubuntu-docs:
ubuntu-docs depends on yelp; however:
Package yelp is not configured yet.
dpkg: error processing package ubuntu-docs (--configure):
dpkg: dependency problems prevent configuration of evolution-data-server:
evolution-data-server depends on libedataserverui-1.2-2 (= 3.36.4-0ubuntu1); however:
Package libedataserverui-1.2-2:amd64 is not configured yet.
dpkg: error processing package evolution-data-server (--configure):
dpkg: dependency problems prevent configuration of network-manager-gnome:
network-manager-gnome depends on gnome-shell | policykit-1-gnome | polkit-1-auth-agent; however:
Package policykit-1-gnome is not installed.
Package polkit-1-auth-agent is not installed.
Package gnome-shell which provides polkit-1-auth-agent is not configured yet.
dpkg: error processing package network-manager-gnome (--configure):
dpkg: dependency problems prevent configuration of gnome-user-docs:
gnome-user-docs depends on ubuntu-docs (>= 18.04.1~); howevNo apport report written because MaxReports is reached already
er:
Package ubuntu-docs is not configured yet.
gnome-user-docs depends on yelp (>= 3); however:
dpkg: error processing package gnome-user-docs (--configure):
dictionaries-common
aspell-en
aspell
hunspell-en-us
enchant-2
enchant
yelp
libyelp0:amd64
zenity
mutter
gnome-shell
ubuntu-session
gdm3
ubuntu-docs
gnome-user-docs
Edit: Could this have to do with Emacs? I installed it using this:
## install dependencies (got those from all over the net and from the snap)
sudo apt install -y autoconf automake autotools-dev bsd-mailx build-essential
diffstat gnutls-dev imagemagick libasound2-dev libc6-dev libdatrie-dev
libdbus-1-dev libgconf2-dev libgif-dev libgnutls28-dev libgpm-dev libgtk2.0-dev
libgtk-3-dev libice-dev libjpeg-dev liblockfile-dev liblqr-1-0 libm17n-dev
libmagickwand-dev libncurses5-dev libncurses-dev libotf-dev libpng-dev
librsvg2-dev libsm-dev libthai-dev libtiff5-dev libtiff-dev libtinfo-dev libtool
libx11-dev libxext-dev libxi-dev libxml2-dev libxmu-dev libxmuu-dev libxpm-dev
libxrandr-dev libxt-dev libxtst-dev libxv-dev quilt sharutils texinfo xaw3dg
xaw3dg-dev xorg-dev xutils-dev zlib1g-dev libjansson-dev libxaw7-dev
libselinux1-dev libmagick++-dev libacl1-dev gir1.2-javascriptcoregtk-4.0
gir1.2-webkit2-4.0 libenchant1c2a libglvnd-core-dev libicu-le-hb-dev
libidn2-0-dev libjavascriptcoregtk-4.0-dev liboss4-salsa2 libsoup2.4-dev
libsystemd-dev libwebkit2gtk-4.0-dev libx11-xcb-dev libxcb-dri2-0-dev
libxcb-dri3-dev libxcb-glx0-dev libxcb-present-dev libxshmfence-dev
x11proto-composite-dev x11proto-core-dev x11proto-damage-dev
x11proto-fixes-dev
download and install
cd ~
wget https://ftp.gnu.org/pub/gnu/emacs/emacs-27.1.tar.gz
tar -xzvf emacs-27.1.tar.gz
cd emacs-27.1
./configure
make
sudo make install
rm ~/emacs-27.1.tar.gz
as presented in this guide and thought it would work and it seems to be more or less functioning well.
