I tried installing version 4.0.5.tar.gz on an Ubuntu 18.04 LTS server at school but it failed following instructions here that say:
shell$ gunzip -c openmpi-4.0.5.tar.gz | tar xf -
shell$ cd openmpi-4.0.5
shell$ ./configure --prefix=/usr/local
<...lots of output...>
shell$ make all install
So I tried version 3.1.6 and it failed again.
The error was:
  make[2]: Nothing to be done for 'install-exec-am'.
 /bin/mkdir -p '/usr/local/share/openmpi/amca-param-sets'
 /usr/bin/install -c -m 644 amca-param-sets/example.conf '/usr/local/share/openmpi/amca-param-sets'
/usr/bin/install: cannot remove '/usr/local/share/openmpi/amca-param-sets/example.conf': Permission denied
Makefile:1806: recipe for target 'install-dist_amca_paramDATA' failed
make[2]: *** [install-dist_amca_paramDATA] Error 1
make[2]: Leaving directory '/home/T00057442/openmpi31/openmpi-3.1.6/contrib'
Makefile:1897: recipe for target 'install-am' failed
make[1]: *** [install-am] Error 2
make[1]: Leaving directory '/home/T00057442/openmpi31/openmpi-3.1.6/contrib'
Makefile:1896: recipe for target 'install-recursive' failed
make: *** [install-recursive] Error 1
for version 3.1.6 on the server and locally:
/bin/mkdir: cannot create directory ‘/usr/local/share/openmpi’: Permission denied
Makefile:1789: recipe for target 'install-dist_amca_paramDATA' failed
make[2]: Leaving directory '/media/nobu/UbuntuFiles/Downloads/openmpi-4.0.5/contrib'
Makefile:1880: recipe for target 'install-am' failed
make[1]: Leaving directory '/media/nobu/UbuntuFiles/Downloads/openmpi-4.0.5/contrib'
Makefile:1879: recipe for target 'install-recursive' failed
so both times it is install-am? What is that and has anyone successfully installed openmpi or mpich? I need it for Ray Surveyor: http://zorino.github.io/raysurveyor-tutorial/#/42
Edit: I run
base) nobu@gold3forever:~/Desktop/BioInformatics/RA/kover/ray$ mpiexec --version
mpiexec: error while loading shared libraries: libopen-rte.so.40: cannot open shared object file: No such file or directory
then I tried:
(base) nobu@gold3forever:~/Desktop/BioInformatics/RA/kover/ray$ mpirun --version
mpirun: error while loading shared libraries: libopen-rte.so.40: cannot open shared object file: No such file or directory
Finally
(base) nobu@gold3forever:~/Desktop/BioInformatics/RA/kover/ray$ mpicxx --showme:version
mpicxx: error while loading shared libraries: libopen-pal.so.40: cannot open shared object file: No such file or directory
I thought I was okay, following directions from @NOrbert in his answer but when I try to install Ray Surveyor I get
(base) nobu@gold3forever:~/Desktop/BioInformatics/RA/kover/ray$ make PREFIX=`pwd`/BUILD MAXKMERLENGTH=64 HAVE_LIBZ=y HAVE_LIBBZ2=y ASSERT=n;
  CXX code/application_core/ray_main.o
Makefile:160: recipe for target 'code/application_core/ray_main.o' failed
make: *** [code/application_core/ray_main.o] Error 127
Per the comment above, sudo ldconfig I read on that link after the steps provided by @NOrbert.
You do not need to compile OpenMPI by yourself.
This package is presented in Ubuntu repositories.
Simply install it with:
sudo apt-add-repository universe
sudo apt-get install libopenmpi-dev
and then continue with compilation of only Ray Surveyor.
N0rbert
  • 103,263
I got this error while trying to install OpenMPI 4.0.0 in Ubuntu 18.04. I wanted this particular version for another library. I solved this by running sudo make all install instead of make all install. You can notice this error in the error logs in the question too (Permission denied).
