I have 2 drives one that shipped with my laptop and another I pulled from my old laptop that previously had Ubuntu on it. It's a few years old but I would like to extend my storage so I can stop getting the low disk storage message and then I can use my laptop for more school work and to help me start learning python. Is there any resources I can use to better understand how my Linux OS uses storage and how to better read and understand what I'm seeing here?
Disk /dev/loop0: 9.7 MiB, 9510912 bytes, 18576 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/loop1: 8.54 MiB, 8945664 bytes, 17472 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop2: 97.72 MiB, 102445056 bytes, 200088 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop3: 97.6 MiB, 101777408 bytes, 198784 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop4: 55.33 MiB, 58007552 bytes, 113296 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop5: 54.97 MiB, 57614336 bytes, 112528 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop6: 57.33 MiB, 60108800 bytes, 117400 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop7: 57.42 MiB, 60194816 bytes, 117568 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/nvme0n1: 238.49 GiB, 256060514304 bytes, 500118192 sectors Disk model: INTEL SSDPEKKW256G7
Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: EFA94F34-B396-44F6-9FEA-937E13C836EADevice Start End Sectors Size Type /dev/nvme0n1p1 2048 206847 204800 100M EFI System /dev/nvme0n1p2 206848 239615 32768 16M Microsoft reserved /dev/nvme0n1p3 239616 498006015 497766400 237.4G Microsoft basic data /dev/nvme0n1p4 498008064 500105215 2097152 1G Windows recovery environment
Disk /dev/sda: 931.53 GiB, 1000204886016 bytes, 1953525168 sectors Disk model: ST1000LM014-1EJ1 Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: dos Disk identifier: 0x9aa4dd4d
Device Boot Start End Sectors Size Id Type /dev/sda1 * 2048 718847 716800 350M 7 HPFS/NTFS/exFAT /dev/sda2 718848 975417991 974699144 464.8G 7 HPFS/NTFS/exFAT /dev/sda3 975419392 976961535 1542144 753M 82 Linux swap / Solaris /dev/sda4 976963582 1953523711 976560130 465.7G 5 Extended /dev/sda5 976963584 1016023039 39059456 18.6G 83 Linux /dev/sda6 1016025088 1953523711 937498624 447G 83 Linux
Partition 4 does not start on physical sector boundary.
Disk /dev/loop8: 217.92 MiB, 228478976 bytes, 446248 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop9: 162.89 MiB, 170778624 bytes, 333552 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop10: 44.9 MiB, 47063040 bytes, 91920 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop11: 161.42 MiB, 169254912 bytes, 330576 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop12: 62.9 MiB, 65105920 bytes, 127160 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop13: 144.98 MiB, 151998464 bytes, 296872 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop14: 144.25 MiB, 151248896 bytes, 295408 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop15: 290.45 MiB, 304545792 bytes, 594816 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop16: 50.69 MiB, 53133312 bytes, 103776 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop17: 133.1 MiB, 139472896 bytes, 272408 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop18: 202.92 MiB, 212758528 bytes, 415544 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
EDIT: This is what is shown when I use df -h. Definitely shows me more information and how my system is storing everything.
df -h Filesystem Size Used Avail Use% Mounted on udev 7.8G 0 7.8G 0% /dev tmpfs 1.6G 91M 1.5G 6% /run /dev/sda5 19G 15G 2.8G 85% / tmpfs 7.8G 299M 7.5G 4% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup /dev/loop0 9.2M 9.2M 0 100% /snap/canonical-livepatch/95 /dev/loop3 98M 98M 0 100% /snap/core/9993 /dev/loop1 8.7M 8.7M 0 100% /snap/canonical-livepatch/90 /dev/loop2 98M 98M 0 100% /snap/core/10126 /dev/loop4 56M 56M 0 100% /snap/core18/1885 /dev/loop5 55M 55M 0 100% /snap/core18/1705 /dev/loop6 58M 58M 0 100% /snap/discord/112 /dev/loop7 58M 58M 0 100% /snap/discord/115 /dev/loop8 218M 218M 0 100% /snap/gnome-3-34-1804/60 /dev/loop9 163M 163M 0 100% /snap/gnome-3-28-1804/145 /dev/loop10 45M 45M 0 100% /snap/gtk-common-themes/1440 /dev/loop11 162M 162M 0 100% /snap/gnome-3-28-1804/128 /dev/loop12 63M 63M 0 100% /snap/gtk-common-themes/1506 /dev/loop13 145M 145M 0 100% /snap/notepadqq/855 /dev/loop14 145M 145M 0 100% /snap/notepadqq/841 /dev/loop15 291M 291M 0 100% /snap/vlc/1700 /dev/loop16 51M 51M 0 100% /snap/snap-store/481 /dev/loop17 134M 134M 0 100% /snap/notepadqq/115 /dev/loop18 203M 203M 0 100% /snap/vlc/1397 /dev/sda6 440G 52G 366G 13% /home tmpfs 1.6G 24K 1.6G 1% /run/user/127 tmpfs 1.6G 84K 1.6G 1% /run/user/1000 /dev/sda2 465G 303M 465G 1% /media/USER/HP_LNX /dev/nvme0n1p3 238G 94G 144G 40% /media/USER/Acer
