Unable to install vs code showing status-code=409 kind= snap-change-cnflict massage=snaop "code" has"install snap" change in progress, plz guide for complete installation !
Asked
Active
Viewed 1.8k times
That's a way too common issue. It is possible that you have enabled automatic updates from your Ubuntu Settings and you tried to install something while that process was running.
You could wait for it to finish the update (there are no visual clues whatsoever) or you could try to kill the snapd process.
The brutal soulution would be to reboot your system, run updates and then install VS Code.
sudo reboot
Then, when it's up and running again....
sudo snap refresh
sudo snap install code
Hope this helps.
Mattia
- 486
