I'm trying to connect to my Ubuntu VPS (8 core CPU, 24gb ram) using Windows 10 Remote Desktop Connection. I followed the instructions here:
https://linuxize.com/post/how-to-install-xrdp-on-ubuntu-18-04/
It's virtually impossible to do anything. It's so slow it nearly takes 15 seconds for something to happen like typing in the console or openening up the browser. I went through many threads here with similar problems but did not have any success.
I tried the latest Ubuntu version as well with no luck.
My Linux knowledge is very limited so will appreciate some assistance here.
Any idea whatI can try next ?
ceds
  • 123
The default settings for an XRDP installation are not optimized. To increase XRDP performance try the following:
Make a backup of the configuration file:
cp /etc/xrdp/xrdp.ini /etc/xrdp/xrdp.ini.bck
Now edit the configuration file:
nano /etc/xrdp/xrdp.ini
Inside the file edit the variables "max_bpp", "xserverbpp" and "crypt_level", these are optimized values:
max_bpp = 128
xserverbpp = 128
crypt_level = low
It is convenient to add the variable "max_bpp" the variable "use_compression" with the following value:
use_compression = yes
Finally, when connecting low, lower the color quality to 16 bits instead of 32 bits.
kyodake
  • 17,808
