you can translate with the translator if you want
Tengo Ubuntu instalado y Windows 10 también en un HDD de 1TB, 900G para Windows y 100G para Ubuntu, debido a que me quedo sin espacio y el Windows 10 esta roto y no funciona
Quiero quitar la partición del Windows 10 y darle todo el espacio disponible a Ubuntu
para ello usare Partition Magic
-- ENGLISH--
I have Ubuntu installed and Windows 10 also on a 1TB HDD, 900G for Windows and 100G for Ubuntu, because I run out of space and Windows 10 is broken and does not work
I want to remove the partition from Windows 10 and give all available space to Ubuntu
for this I will use Partition Magic
With gparted, delete the partition corresponding to MS Windows and create a new one in ext4 format, do not delete UEFI partitions if any, only the one from MS Windows.
Then move your / home to this partition.
Suppose de new home is /dev/sda3
Open a terminal and run:
exec sudo -i
mkdir /media/hometemp
mount /dev/sda3 /media/hometemp
cd /home
cp -ax . /media/hometemp
cd /
mv /home /home.old
mkdir /home
umount /dev/sda3
mount /dev/sda3 /home
exit
If everything works, add the UUID in /etc/fstab to /dev/sda3.
exec sudo -i
blkid /dev/sda3
gedit /etc/fstab
You must add the lines at the bottom of the file to mount your new /home directory
Type the UUUI of the partition at the start of the line, (UUID= sda3 UUID) and then press Tab.
Type the mount point, /home, and press Tab.
Type the filesystem description ext4, and press Tab.
Type defaults for the mount options, and press Tab.
Type the digit 0 for the filesystem dump option, and press Tab.
Type the digit 0 for the filesystem check option.
Save the fstab file, close Gedit and reboot.
Once you’re perfectly sure that you no longer need the safety copy of your old /home directory, you can delete it:
cd /
sudo rm -rf home.old/
kyodake
  • 17,808
