I'm trying to make Ubuntu 20.04 recognise AirPods Pro as a headset (not just as headphones). I tried to follow the instructions in this answer.
list-modems returns the following output:
[ /phonesim ]
    Online = 0
    Powered = 0
    Lockdown = 0
    Emergency = 0
    Interfaces =
    Features =
    Type = hardware
But when I try to run the enable-modem command from a freshly checked-out ofono git repo (commit 285fad8f39d46a5f0a0f9d194789978227558d1e), I get the following error:
Connecting modem /phonesim...
Traceback (most recent call last):
  File "./enable-modem", line 20, in <module>
    modem.SetProperty("Powered", dbus.Boolean(1), timeout = 120)
  File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 72, in __call__
    return self._proxy_method(*args, **keywords)
  File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 141, in __call__
    return self._connection.call_blocking(self._named_service,
  File "/usr/lib/python3/dist-packages/dbus/connection.py", line 652, in call_blocking
    reply_message = self.send_message_with_reply_and_block(
dbus.exceptions.DBusException: org.ofono.Error.Failed: Operation failed
What does the error mean, and how could I get around it?
Zoltán
  • 826
The problem was that I didn't leave phonesim running, which is why enable-modem was complaining.
So the command
ofono-phonesim -p 12345 /usr/share/phonesim/default.xml
needs to be left running before running enable-modem. See my answer here on how to automate this: https://askubuntu.com/a/1278587/119592
Zoltán
  • 826
