04.1 as a dual boot with GRUB. I was installing openFOAM and then I tried to upgrade packages using the usual sudo apt-get upgrade but I keep getting errors for standard packages.
This is the output of the sudo apt-get update:
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Get:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease [111 kB]
Get:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease [98.3 kB]
Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [107 kB]
Get:6 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 DEP-11 Metadata [229 kB]
Get:7 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 DEP-11 Metadata [202 kB]
Get:8 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 c-n-f Metadata [12.3 kB]
Get:9 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 DEP-11 Metadata [2,468 B]
Get:10 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 DEP-11 Metadata [1,768 B]
Get:11 http://archive.ubuntu.com/ubuntu focal-security/main amd64 DEP-11 Metadata [24.3 kB]
Get:12 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 DEP-11 Metadata [55.6 kB]
Hit:3 https://sourceforge.net/projects/openfoam/files/repos/deb focal InRelease
Fetched 844 kB in 3s (293 kB/s)
Reading package lists... Done
and here is the output of the sudo apt-get upgrade:
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
10 not fully installed or removed.
Need to get 0 B/3,441 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
dpkg: dependency problems prevent configuration of mutter:
mutter depends on adwaita-icon-theme; however:
Package adwaita-icon-theme is not installed.
dpkg: error processing package mutter (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of gnome-shell:
gnome-shell depends on mutter (>= 3.36.0); however:
Package mutter is not configured yet.
dpkg: error processing package gnome-shell (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of ibus:
ibus depends on adwaita-icon-theme; however:
dpkg: error processing package ibus (--configure):
dpkg: dependency problems prevent configuration of gdm3:
gdm3 depends on gnome-shell (>= 3.19.92); however:
Package gnome-shell is not configured yet.
dpkg: error processing package gdm3 (--configure):
dpkg: dependency problems prevent configuration of libmutter-6-0:amd64:
libmutter-6-0:amd64 depends on adwaita-icon-theme; however:
dpkg: error processing package libmutter-6-0:amd64 (--configure):
dpkg: dependency problems prevent configuration of ubuntu-desktop:
ubuntu-desktop depends on gdm3; however:
Package gdm3 is not configured yet.
ubuntu-desktop depends on gnome-shell; however:
Package gnome-sheNo apport report written because MaxReports is reached already
dpkg: error processing package ubuntu-desktop (--configure):
dpkg: dependency problems prevent configuration of gir1.2-mutter-6:amd64:
gir1.2-mutter-6:amd64 depends on libmutter-6-0 (= 3.36.6-1ubuntu0.20.04.2); however:
Package libmutter-6-0:amd64 is not configured yet.
dpkg: error processing package gir1.2-mutter-6:amd64 (--configure):
dpkg: dependency problems prevent configuration of gnome-shell-extension-desktop-icons:
gnome-shell-extension-desktop-icons depends on gnome-shell (>= 3.33); however:
dpkg: error processing package gnome-shell-extension-desktop-icons (--configure):
dpkg: dependency problems prevent configuration of ubuntu-desktop-minimal:
ubuntu-desktop-minimal depends on gdm3; however:
ubuntu-desktop-minimal depends on gnome-shell; however:
ubuntu-desktop-minimal depends on gnome-shell-extension-desktop-icons; however:
Package gnome-shell-extension-desktop-icons is not configured yet.
dpkg: error processing package ubuntu-desktop-minimal (--configure):
dpkg: dependency problems prevent processing triggers for libgtk-3-0:amd64:
libgtk-3-0:amd64 depends on adwaita-icon-theme; however:
dpkg: error processing package libgtk-3-0:amd64 (--configure):
dependency problems - leaving triggers unprocessed
dpkg: dependency problems prevent processing triggers for libgtk2.0-0:amd64:
libgtk2.0-0:amd64 depends on adwaita-icon-theme | gnome-icon-theme; however:
Package gnome-icon-theme is not installed.
dpkg: error processing package libgtk2.0-0:amd64 (--configure):
mutter
gnome-shell
ibus
gdm3
libmutter-6-0:amd64
ubuntu-desktop
libgtk-3-0:amd64
libgtk2.0-0:amd64
I've tried to follow this tutorial and remove each package individually and reinstall them but I am not able to remove them as they are other packages depend on them. Also it says that adwaita-icon-theme is not installed but when I try to install it its says it already exists. What would be the best method of attack? I do not have alot of data on it so i would be able to wipe the drive and reinstall ubuntu if that's easier. Thanks.
