When I try to query the command apt-get update, I get an error message:
OK:1 http://ppa.launchpad.net/ondrej/php/ubuntu bionic InRelease
OK:2 http://de.archive.ubuntu.com/ubuntu bionic InRelease
OK:3 http://de.archive.ubuntu.com/ubuntu bionic-updates InRelease
OK:4 http://ppa.launchpad.net/seafile/seafile-client/ubuntu bionic InRelease
OK:5 http://de.archive.ubuntu.com/ubuntu bionic-backports InRelease
Ign:6 https://packages.sury.org/php bionic InRelease
Fehl:7 https://packages.sury.org/php bionic Release
  404  Not Found [IP: 104.31.95.169 443]
Holen:8 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
Paketlisten werden gelesen... Fertig
E: The archivbe "https://packages.sury.org/php bionic Release" does not have a release file.
N: Updating from such a repository cannot be done in a secure way, so it is disabled by default.
N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
karel
  • 122,292
  • 133
  • 301
  • 332
User66
make sure your repositories are set on the nearest server: go to software and update, there you can select a server (most of the times you should chose your country). check your internet and try sudo apt dist-upgrade
Raman
  • 111
The simplest solution is this:
  1. Go to "Software & Sources/Updates" application.
  2. In the other software tab, you should see your erring PPA, which is https://packages.sury.org/php bionic Release
  3. Remove the said entry from the sources.
  4. Try the update again.
This should solve the problem.
