I have a problem with Cisco PacketTracer
https://www.netacad.com/courses/packet-tracer
wolf@linux:/opt/pt/bin$ ./PacketTracer7
./PacketTracer7: error while loading shared libraries: libQt5WebEngineWidgets.so.5: cannot open shared object file: No such file or directory
It turns out that some of the libraries are not there:
wolf@linux:/opt/pt/bin$ ldd PacketTracer7 | grep not
libQt5WebEngineWidgets.so.5 => not found
libQt5WebEngineCore.so.5 => not found
libQt5Script.so.5 => not found
libQt5ScriptTools.so.5 => not found
I've tried to install it, but it didn't work:
wolf@linux:/opt/pt/bin$ sudo apt install libQt5WebEngineWidgets.so.5 libQt5WebEngineCore.so.5 libQt5Script.so.5 libQt5ScriptTools.so.5
Reading package lists... Done
Building dependency tree
E: Unable to locate package libQt5WebEngineWidgets.so.5
E: Unable to locate package libQt5WebEngineCore.so.5
E: Unable to locate package libQt5Script.so.5
E: Unable to locate package libQt5ScriptTools.so.5
I've also tried to change it to lower case and remove .so.5 from the name, but it still didn't work.
sudo apt install libQt5WebEngineWidgets.so libQt5WebEngineCore.so libQt5Script.so libQt5ScriptTools.so
sudo apt install libQt5WebEngineWidgets libQt5WebEngineCore libQt5Script libQt5ScriptTools
sudo apt install libqt5webenginewidgets libqt5webenginecore libqt5script libqt5scripttools
What is the right way to do this?
Update
This will install the first two libraries which are libQt5WebEngineWidgets.so.5 & libQt5WebEngineCore.so.5, but not the last two:
sudo apt install libqt5webenginewidgets5 libqt5webenginecore5
Two more libraries to be installed:
wolf@linux:/opt/pt/bin$ ldd ./PacketTracer7 | g not
