11
Since updating, natural scrolling works just fine - up until reboot. Toggling the setting off and on again does the trick, but is rather... Annoying.
Grateful for any advice!
Scrounger
  • 113
edit:
I just found a better solution / workaround to my original answer:
Add Option "NaturalScrolling" "on" to /usr/share/X11/xorg.conf.d/40-libinput.conf
In context:
Section "InputClass"
        Identifier "libinput pointer catchall"
        MatchIsPointer "on"
        MatchDevicePath "/dev/input/event*"
        Driver "libinput"
EndSection
Then restart the X session (i.e.: log out or restart)
skiss
  • 146
I've noticed the same; it's really annoying. Mine also "forgets" the setting I have for Caps Lock (make it an Esc), which drives me crazy.
The following two terminal commands will fix things
gsettings set org.gnome.desktop.peripherals.mouse natural-scroll true
And for my escape problem: gsettings set org.gnome.desktop.input-sources xkb-options "['caps:escape']"
(edit2) Since I've turned the settings off and on again in the terminal, they haven't magically disappeared. Maybe it's enough to just run the below once? (turn it off and on again :) )
gsettings set org.gnome.desktop.peripherals.mouse natural-scroll false
mwmwm
  • 141
