Tried updating my system today. The updates went through, but the following error persists when I use sudo apt autoremove or sudo apt upgrade
sudo apt autoremove
Reading package lists... Done
Building dependency tree
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-headers-5.4.0-48-generic (5.4.0-48.52) ...
/etc/kernel/header_postinst.d/dkms:
 * dkms: running auto installation service for kernel 5.4.0-48-generic
Error! Could not locate dkms.conf file.
File: /var/lib/dkms/anbox-ashmem/1/source/dkms.conf does not exist.
   ...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 4
dpkg: error processing package linux-headers-5.4.0-48-generic (--configure):
 installed linux-headers-5.4.0-48-generic package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-headers-generic:
 linux-headers-generic depends on linux-headers-5.4.0-48-generic; however:
  Package linux-headers-5.4.0-48-generic is not configured yet.
dpkg: error processing package linux-headers-generic (--configure): dependency problems - leaving unconfigured Setting up linux-image-5.4.0-48-generic (5.4.0-48.52) ... No apport report written because the error message indicates it's a follow-up error from a previous failure. dpkg: dependency problems prevent configuration of linux-generic: linux-generic depends on linux-headers-generic (= 5.4.0.48.51); however: Package linux-headers-generic is not configured yet.
dpkg: error processing package linux-generic (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates it's a follow-up error from a previous failure. Processing triggers for linux-image-5.4.0-48-generic (5.4.0-48.52) ... /etc/kernel/postinst.d/dkms:
  • dkms: running auto installation service for kernel 5.4.0-48-generic
Error! Could not locate dkms.conf file. File: /var/lib/dkms/anbox-ashmem/1/source/dkms.conf does not exist. ...fail! run-parts: /etc/kernel/postinst.d/dkms exited with return code 4 dpkg: error processing package linux-image-5.4.0-48-generic (--configure): installed linux-image-5.4.0-48-generic package post-installation script subprocess returned error exit status 1 No apport report written because MaxReports has already been reached Errors were encountered while processing: linux-headers-5.4.0-48-generic linux-headers-generic linux-generic linux-image-5.4.0-48-generic E: Sub-process /usr/bin/dpkg returned an error code (1)
I am using a custom kernel
uname -r
5.8.9-050809-generic
I googled the first error that mentions anbox-ashmem and I saw some very complicated (for me) discussions, hence I decided to post here to avoid breaking my system. I can restart and use everything normally at the moment.
sudo dpkg-reconfigure [package] seems to be a popular fix for this, however it doesn't always work.
Solution from and possible duplicate of: `Error! Could not locate dkms.conf file`
Vasilisa
  • 579
  • 15
