I did ran the commands in this and this posts, but got the following errors which chili555 mentioned but still my signal keeps being weak.
Tried changing config_enabled to x2apic_enabled with no luck.
EDIT: After following chili555's answer i ran the -uname -r command and it returned this
4.15.0-118-generic
So I downloaded v4.14-rc2/ and it gave this error:
/home/yanes/backports-4.14-rc2-1/drivers/net/wireless/ath/ath10k/htt_rx.c: In function ‘ath10k_htt_rx_alloc’: /home/yanes/backports-4.14-rc2-1/drivers/net/wireless/ath/ath10k/htt_rx.c:510:2: error: implicit declaration of function ‘setup_timer’; did you mean ‘sk_stop_timer’? [-Werror=implicit-function-declaration] setup_timer(timer, ath10k_htt_rx_ring_refill_retry, (unsigned long)htt); ^~~~~~~~~~~ sk_stop_timer cc1: some warnings being treated as errors scripts/Makefile.build:330: recipe for target '/home/yanes/backports-4.14-rc2-1/drivers/net/wireless/ath/ath10k/htt_rx.o' failed make[8]: *** [/home/yanes/backports-4.14-rc2-1/drivers/net/wireless/ath/ath10k/htt_rx.o] Error 1 scripts/Makefile.build:604: recipe for target '/home/yanes/backports-4.14-rc2-1/drivers/net/wireless/ath/ath10k' failed make[7]: *** [/home/yanes/backports-4.14-rc2-1/drivers/net/wireless/ath/ath10k] Error 2 scripts/Makefile.build:604: recipe for target '/home/yanes/backports-4.14-rc2-1/drivers/net/wireless/ath' failed make[6]: *** [/home/yanes/backports-4.14-rc2-1/drivers/net/wireless/ath] Error 2 scripts/Makefile.build:604: recipe for target '/home/yanes/backports-4.14-rc2-1/drivers/net/wireless' failed make[5]: *** [/home/yanes/backports-4.14-rc2-1/drivers/net/wireless] Error 2 Makefile:1585: recipe for target 'module/home/yanes/backports-4.14-rc2-1' failed make[4]: *** [module/home/yanes/backports-4.14-rc2-1] Error 2 Makefile.build:6: recipe for target 'modules' failed make[3]: *** [modules] Error 2 Makefile.real:88: recipe for target 'modules' failed make2: *** [modules] Error 2 Makefile:40: recipe for target 'modules' failed make1: *** [modules] Error 2 Makefile:30: recipe for target 'default' failed make: *** [default] Error 2
EDIT 2: My laptop freezes unless I turn the wi-fi off, tried installing older version instead of newer (v4.1.1) by disabling wi-fi but It returns that I have no permission? Here's the output.
make2: execvp: ./lxdialog/check-lxdialog.sh: Permission denied make2: execvp: ./lxdialog/check-lxdialog.sh: Permission denied make2: 'conf' is up to date. make1: execvp: ./kconf/conf: Permission denied Makefile.real:41: recipe for target 'defconfig-ath10k' failed make1: *** [defconfig-ath10k] Error 127 Makefile:40: recipe for target 'defconfig-ath10k' failed make: *** [defconfig-ath10k] Error 2
A backport file from 2015 is unlikely to successfully compile in more modern kernel versions. Please note the answer at the link you gave that says, in part:
Before executing the wget command check for you linux kernel version.
$ uname -r
Then go to https://mirrors.edge.kernel.org/pub/linux/kernel/projects/backports/stable/ and check for the closest kernel version available there and then download the backports tar file using the following command.
For example, if uname -r returns 5.4.0-48-generic, then select the backport version that closely matches. In this case select https://mirrors.edge.kernel.org/pub/linux/kernel/projects/backports/stable/v5.4.56/backports-5.4.56-1.tar.gz
It compiles without error on my 5.4.0-48 machine.
chili555
  • 61,330
First Method:
sudo apt update && sudo apt upgrade
sudo apt install --reinstall linux-firmware
2nd Method
(this method solved my issue)
sudo apt remove broadcom-sta-dkms bcmwl-kernel-source
sudo apt install firmware-b43-installer
3rd Method:
sudo apt install fwupd
sudo fwupdmgr refresh && sudo fwupdmgr update
sudo reboot
4th Method :
After few days of testing, it looks like a firmware problem to me. I've tested all the ones available at https://github.com/kvalo/ath10k-firmware/tree/master/QCA9377/hw1.0 and I experienced the very same issue with all the three API6 files (i.e. firmware-6.bin_*).
The latest (in terms of release date) API5 file firmware-5.bin_WLAN.TF.1.0-00023-QCATFSWPZ-1 seemed to work much better but I still experienced the issue after few solid hours.
Eventually, the file firmware-5.bin_CNSS.TF.1.0-00267-QCATFSWPZ-1 seems to be the most stable on my Lenovo Ideapad 320 using:
Network controller: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter (rev 31)
So try renaming the existing firmware-5.bin and firmware-6.bin files under /lib/firmware/ath10k/QCA9377/hw1.0/ and use the firmware version I've mentioned. In other words...
 cd /lib/firmware/ath10k/QCA9377/hw1.0/
sudo mv firmware-5.bin firmware-5.bin.orig
sudo mv firmware-6.bin firmware-6.bin.orig
 sudo wget "https://github.com/kvalo/ath10k-firmware/blob/master/QCA9377/hw1.0/CNSS.TF.1.0/firmware-5.bin_CNSS.TF.1.0-00267-QCATFSWPZ-1?raw=true" -O firmware-5.bin
Now load the new firmware and double-check
 sudo modprobe -r ath10k_pci
 sudo modprobe ath10k_pci
 sudo dmesg | grep ath10k
output:
ath10k_pci 0000:01:00.0: firmware: direct-loading firmware ath10k/QCA9377/hw1.0/firmware-5.bin
ath10k_pci 0000:01:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 17aa:0901
ath10k_pci 0000:01:00.0: kconfig debug 0 debugfs 0 tracing 0 dfs 0 testmode 0
ath10k_pci 0000:01:00.0: firmware ver CNSS.TF.1.0-00267-QCATFSWPZ-1 api 5 features ignore-otp crc32 d6b81b3c
ath10k_pci 0000:01:00.0: firmware: direct-loading firmware ath10k/QCA9377/hw1.0/board-2.bin
ath10k_pci 0000:01:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
ath10k_pci 0000:01:00.0: unsupported HTC service id: 1536
ath10k_pci 0000:01:00.0: htt-ver 3.1 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
Make sure the version id just next to firmware ver matches.
I hope this trick will solve that annoying issue for you too ;)
