I am using Ubuntu 16.04.
I have installed HPLIP from the Ubuntu repository using the command sudo apt install hplip hplip-gui as recommended in How to install HPLIP on my Ubuntu to support my HP printer and/or scanner?.
However, when I run hp-setup I am told to install HPLIP.
The program 'hp-setup' is currently not installed. You can install it by typing:
This is circular since I have HPLIP already installed. Can anyone suggest what I should do next?
Output of sudo apt install hplip:
Reading package lists... Done
Building dependency tree
hplip is already the newest version (3.16.3+repack0-1).
0 upgraded, 0 newly installed, 0 to remove and 27 not upgraded.
The output confirms it is installed.
Output of dpkg -l hplip:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                        Version            Architecture       Description
ii  hplip                       3.16.3+repack0-1   amd64              HP Linux Printing and Imaging System (HPLIP)
Zanna
  • 72,312
HappyLarry
  • 31
