I started using Ubuntu a very short time ago, and it was working perfectly! I upgraded to 12.04 yesterday, and today I realize that everything is running slow. For example, video streaming online, from sites such as Youtube is not working correctly, audio and video breaks constantly. I have a 64 bit system, with a Intel® Core™2 Duo, 2.10GHz × 2 . I don't know what more to add.
I tried free -m on the terminal, it returned that I had only 524MB free from 3858MB. All that i have running at this point is Mozilla Firefox.
5 Answers5
From your brief description of videos playing slowly in Firefox, it's possible that you no longer have a genuine (proprietary) version of the Adobe Flash Player installed.
This is a really easy way to do that:
sudo apt-get install ubuntu-restricted-extras
This installs Adobe Flash Player along with a bunch of other things that are not open source, but you're likely to benefit from such as non-free codecs for Ubuntu's built-in video players.
If you find an error installing this package, it's possible that you don't have the non-free repositories enabled. You'll want the top four of these checked under Software Sources in your system configuration.
Ravan
  • 9,567
thomasrutter
  • 37,804
In my experience, Firefox sometimes have episodes of.. well, extereme memory consumption - which quite possibly are not caused by some problem in Firefox itself but maybe some rogue javascript or flash movie on some page which you currently have opened.
Restarting Firefox helps in such cases.
You can check memory consumption of individual applications using System Monitor application.
Sergey
  • 44,353
I have the same problem and has solved it by switching from ubuntu to lubuntu.
You can find how to switch from Is there an easy way to change Ubuntu flavor during upgrade?
I think the problem is unity player causing the lag.
Anonymous
  • 101
AND there is one more possibility, which I must mention as I've experienced it to many times. It seems most any time Ubuntu is upgraded from a previous version it takes several days, or several reboots, to straighten itself out. You can save yourself a lot of grief if you focus on just shutting it down periodically and not stressing about it.
gyropyge
  • 2,568
-2
I experienced a similar problem. I found the solution in https://askubuntu.com/a/131040/1736.
See the post entitled in "tl;dr"
Seth
