I have HP Pavilion - 15-cs3073cl, officially there are no Linux drivers on HP website I have installed Ubuntu 20.04 WiFi is working fine but Ethernet not I have also Windows 10 installed on this laptop and under the Windows Ethernet is working also. Here is the result of command "sudo lshw -C network":
*-network UNCLAIMED
       description: Ethernet controller
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical ID: 0
       bus info: pci@0000:10:00.0
       version: 15
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list
       configuration: latency=0
       resources: ioport:3000(размер=256) память:51004000-51004fff память:51000000-51003fff
There is no option to swith on Ethernet or create a new connection in the setting page
Ethernet setting page
I'm not good in Linux, could anyone help me in this question?
ifconfig
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 866  bytes 75738 (75.7 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 866  bytes 75738 (75.7 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
wlo1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.43.105 netmask 255.255.255.0 broadcast 192.168.43.255 inet6 fe70::c8f6:ef26:54cc:4ef prefixlen 64 scopeid 0x20<link> ether 6c:46:2a:ec:4e:21 txqueuelen 1000 (Ethernet) RX packets 5868 bytes 2778399 (2.7 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 5642 bytes 1122951 (1.1 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
sudo service networking status
etworking.service
     Loaded: masked (Reason: Unit networking.service is masked.)
     Active: inactive (dead) since Thu 2020-10-08 22:11:28 +03; 28min ago
   Main PID: 855 (code=exited, status=0/SUCCESS)
окт 08 22:03:38 Workpc systemd[1]: Starting Raise network interfaces... окт 08 22:03:38 Workpc systemd[1]: Finished Raise network interfaces. окт 08 22:11:28 Workpc systemd[1]: Stopping Raise network interfaces... окт 08 22:11:28 Workpc systemd[1]: networking.service: Succeeded. окт 08 22:11:28 Workpc systemd[1]: Stopped Raise network interfaces.
sudo service network-manager status
etworkManager.service - Network Manager
     Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
     Active: active (running) since Thu 2020-10-08 22:28:27 +03; 13min ago
       Docs: man:NetworkManager(8)
   Main PID: 9577 (NetworkManager)
      Tasks: 3 (limit: 18884)
     Memory: 6.0M
     CGroup: /system.slice/NetworkManager.service
             └─9577 /usr/sbin/NetworkManager --no-daemon
окт 08 22:28:31 Workpc NetworkManager[9577]: <info> [1602185311.8588] dhcp4 (wlo1): state changed unknown -> bound окт 08 22:28:31 Workpc NetworkManager[9577]: <info> [1602185311.8611] device (wlo1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed') окт 08 22:28:31 Workpc NetworkManager[9577]: <info> [1602185311.8646] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed> окт 08 22:28:31 Workpc NetworkManager[9577]: <info> [1602185311.8650] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'manage> окт 08 22:28:31 Workpc NetworkManager[9577]: <info> [1602185311.8655] manager: NetworkManager state is now CONNECTED_LOCAL окт 08 22:28:31 Workpc NetworkManager[9577]: <info> [1602185311.8674] manager: NetworkManager state is now CONNECTED_SITE окт 08 22:28:31 Workpc NetworkManager[9577]: <info> [1602185311.8675] policy: set 'Bruce Lee ' (wlo1) as default for IPv4 routing and DNS окт 08 22:28:31 Workpc NetworkManager[9577]: <info> [1602185311.8681] device (wlo1): Activation: successful, device activated. окт 08 22:28:31 Workpc NetworkManager[9577]: <info> [1602185311.8689] manager: startup complete окт 08 22:28:32 Workpc NetworkManager[9577]: <info> [1602185312.3301] manager: NetworkManager state is now CONNECTED_GLOBAL
cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
#auto dsl-provider #iface dsl-provider inet ppp #pre-up /bin/ip link set eno1 up # line maintained by pppoeconf #provider dsl-provider
#auto eno1 #iface eno1 inet manual
After Disabling the Secure Boot in the BIOS and rebooting it asked me to configure 8168 I select Yes and now all are working fine. Also I switch on Network Boot in the BIOS, maybe that was also a reason. But then not clear why in Windows all was fine.
