let me give some context:
I have a dual booting system (ubuntu 20.04 + Windows 10, over UEFI). Both SOs in the same disk (ssd nvme on m.2 port). Additionally a have a shared partition (same disk) with NTFS file system. I use this shared partition as common place to save Documents, Pics, etc, in both SOs symlinks (Documents, Pics, etc) are point to this partition. I disable fastboot on Windows 10, and boot systems start normally.
The problem appear when I try to use the shared partition on Ubuntu. If configure it to auto mount then Ubuntu "is'n unable to find or create Trash folder". On the other hand, if I mount it manually after startup, the file explorer and other apps work a little strange. I also has a HDD (on sata port) with NTFS and it work without issues (perfect automount and can send files to trash), both has exactly the same config.
I google this issue (unable to find trash folder) and follow the different suggestions without results. The majority of suggestion could be resume on this treath : Unable to find or create trash directory?
Any suggestion or ideas about that ?
  • I am using gnome-disks to configure it (to prevent broken the partition)
Edit: Output of cat /etc/fstab for manual-mount (Without trash issues)
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/nvme0n1p2 during installation
UUID=c034e0e6-a237-47fe-a1e1-419cd036aeea / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/nvme0n1p1 during installation
#UUID=29AB-CF8D /boot/efi vfat umask=0077 0 1
/windows was on /dev/nvme0n1p3 during installation
UUID=1B109D6E67D5A46C /windows ntfs defaults,umask=007,gid=46 0 0
swap was on /dev/nvme0n1p4 during installation
UUID=0be4f712-932c-4243-8b93-fbeb7618593a none swap sw 0 0 UUID=29AB-CF8D /boot/efi vfat defaults 0 1
Output of cat /etc/fstab for automount (With trash issues)
UUID=0be4f712-932c-4243-8b93-fbeb7618593a none swap sw 0 0 UUID=29AB-CF8D /boot/efi vfat defaults 0 1 /dev/disk/by-uuid/C0E810DBE810D190 /mnt/C0E810DBE810D190 auto nosuid,nodev,nofail,x-gvfs-show 0 0
As oldfred comment the nls=utf8,umask=000,uid=1000,gid=1000,windows_names 0 0 combination works perfectly with automount option. No more problems with trash folder or failing to automount on startup. Apparently windows_names 0 0 was the missing command
