-1
I'm trying to upgrade to 20.04.1 but i'm running into problems.
This is my console:
sudo do-release-upgrade
Checking for a new Ubuntu release
Get:1 Upgrade tool signature [1 554 B]
Get:2 Upgrade tool [1 342 kB]
Fetched 1 344 kB in 0s (0 B/s)
authenticate 'focal.tar.gz' against 'focal.tar.gz.gpg'
extracting 'focal.tar.gz'
Reading cache
Checking package manager Reading package lists... Done Building dependency tree
Reading state information... Done Get:1 https://download.docker.com/linux/ubuntu bionic InRelease [64,4 kB]
Hit https://repo.steampowered.com/steam stable InRelease
Hit http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit https://repos.influxdata.com/debian stretch InRelease
Hit https://repo.steampowered.com/steam beta InRelease
Hit http://archive.ubuntu.com/ubuntu bionic InRelease
Hit https://downloads.plex.tv/repo/deb public InRelease
Hit http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Fetched 64,4 kB in 0s (0 B/s)
Checking for installed snaps
Calculating snap size requirements
Updating repository information
Third party sources disabled
Some third party entries in your sources.list were disabled. You can re-enable them after the upgrade with the 'software-properties' tool or your package manager.
To continue please press [ENTER]
Hit http://archive.ubuntu.com/ubuntu focal InRelease
Hit http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit http://security.ubuntu.com/ubuntu focal-security InRelease
Fetched 0 B in 0s (0 B/s)
Calculating the changes
Could not calculate the upgrade
An unresolvable problem occurred while calculating the upgrade.
This was likely caused by:
  • Unofficial software packages not provided by Ubuntu
Please use the tool 'ppa-purge' from the ppa-purge package to remove software from a Launchpad PPA and try the upgrade again.
If none of this applies, then please report this bug using the command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal. If you want to investigate this yourself the log files in '/var/log/dist-upgrade' will contain details about the upgrade. Specifically, look at 'main.log' and 'apt.log'.
Restoring original system state
Aborting Reading package lists... Done
Tried installing ppa-purge but that shows up as not found.
sudo apt install ppa-purge
E: Unable to locate package ppa-purge
What do i do now?
Zucram
  • 17
Turning on Universe and then updating there actually allowed me to install the update!
Zucram
  • 17
