In accordance with the instructions given by https://wiki.geogebra.org/en/Reference:GeoGebra_Installation, I tried installing geogebra by first using sudo apt-add-repository -u 'deb http://www.geogebra.net/linux/ stable main', and then sudo apt install geogebra-classic, but when I run the last command, I get the error message "Unable to locate package geogebra-classic". Any tips?
Asked
Active
Viewed 2,345 times
NickE
- 41
You have add their GPG key by
wget https://static.geogebra.org/linux/office@geogebra.org.gpg.key -O - | sudo apt-key add
and then rerun update and install package:
sudo apt-get update
sudo apt-get install geogebra-classic
N0rbert
- 103,263
First, add the GPG key, then the repository, and finally install by these commands:
$ wget https://static.geogebra.org/linux/office@geogebra.org.gpg.key -O - | sudo apt-key add
$ sudo apt-add-repository -u 'deb http://www.geogebra.net/linux/ stable main'
$ sudo apt install geogebra-classic
Thus the latest Geogebra will be installed.
raf
- 579
Another option is to try GeoGebra Discovery (which is maintained by me) that may address some Linux related issues. It is based on GeoGebra 5.0.641.0 (the classic Java-based user interface). It can be installed as a snap: https://snapcraft.io/geogebra-discovery.
