29
On an fresh Ubuntu 20.04 Server machine with 2 Nvidia GPU cards and i7-5930K, running nvidia-smi shows that 170 MB of GPU memory is being used by /usr/lib/xorg/Xorg.
Since this system is being used for deep learning, we will like to free up as much GPU memory as possible.
Question: How can we prevent gnome and Xorg from taking up 179 MB of GPU memory?
Output of nvidia-smi
Sat Oct  3 20:27:19 2020
| NVIDIA-SMI 450.66       Driver Version: 450.66       CUDA Version: 11.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GeForce GTX 1080    Off  | 00000000:02:00.0 Off |                  N/A |
|  0%   54C    P8    11W / 210W |      7MiB /  8119MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  GeForce GTX 1080    Off  | 00000000:03:00.0 Off |                  N/A |
|  0%   50C    P8    10W / 210W |    179MiB /  8116MiB |      0%      Default |
|                               |                      |                  N/A |
+-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 1109 G /usr/lib/xorg/Xorg 4MiB | | 1 N/A N/A 1109 G /usr/lib/xorg/Xorg 166MiB | | 1 N/A N/A 1189 G /usr/bin/gnome-shell 9MiB | +-----------------------------------------------------------------------------+
Nyxynyx
  • 1,163
  • 16
  • 29
I had the same issue. Many of the suggestions were saying to edit /etc/X11/xorg.conf which doesn't exist for me on Ubuntu 20.04. I needed to keep X11 because I occasionally use X2go or X11 over SSH. I did manage to find a file /usr/share/X11/xorg.conf.d/10-nvidia.conf and then commented out all the lines with #. I was then able to restart X11 with:
sudo systemctl restart display-manager
Voilà, no more GNOME/X11 on GPU.
$ nvidia-smi
Wed Feb  3 19:44:02 2021
| NVIDIA-SMI 450.102.04   Driver Version: 450.102.04   CUDA Version: 11.0     |
|                               |                      |               MIG M. |
|   0  GeForce RTX 208...  Off  | 00000000:01:00.0 Off |                  N/A |
| 27%   33C    P8     1W / 250W |    882MiB / 11019MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  GeForce GTX 1070    Off  | 00000000:4D:00.0 Off |                  N/A |
|  0%   41C    P8    10W / 151W |      2MiB /  8119MiB |      0%      Default |
|                               |                      |                  N/A |
+-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 1075324 C python 879MiB | +-----------------------------------------------------------------------------+
vozman
  • 217
robmsmt
  • 471
I have a setup with Nvidia 2080 GPU. I have observed that remoting into the machine via xrdp leads to a GPU use of only 14 Mb. If a physical screen is connected, it consumes the memory as per the screenshot posted above.
Edit: Even chrome remote desktop leads to xorg consuming just 14 Mb of GPU RAM
Sud Ka
I just figured out today that since I am remote ssh to server, and most the gpu memory is consumed by gnome_shell and xorg, I can simplify "turn off the auto-login" then my gpu memory usaged is reduced from 450MB to 68MB. That's good enough to me.
(base) ➜  /boot nvidia-smi
Sat Apr 15 18:30:57 2023
| NVIDIA-SMI 525.105.17   Driver Version: 525.105.17   CUDA Version: 12.0     |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:26:00.0  On |                  N/A |
|  0%   53C    P8    19W / 240W |     72MiB /  8192MiB |      0%      Default |
|                               |                      |                  N/A |
+-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 69418 G /usr/lib/xorg/Xorg 61MiB | | 0 N/A N/A 69559 G /usr/bin/gnome-shell 7MiB | +-----------------------------------------------------------------------------+
Houcheng
  • 121
