Resolving .local hostnames has become slow since updated from 18.04 to 20.04. Things as simple as:
ping flibble.local
work immediately in 18.04, but take about 5 seconds or so in 20.04, after which it behaves normally. However, it still takes another 5 seconds when run again.
I haven't customized anything since updating. If it matters, Ubuntu is running as a VM in Parallels. I can provide details as necessary.
My /etc/nsswitch.conf file contains the usual:
hosts: files mdns4_minimal [NOTFOUND=return] dns myhostname
I've tried searching for solutions to this problem, but nothing so far has fixed it.
systemctl status systemd-resolved.service output:
● systemd-resolved.service - Network Name Resolution
Loaded: loaded (/lib/systemd/system/systemd-resolved.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-10-05 09:55:47 PDT; 10min ago
Docs: man:systemd-resolved.service(8)
https://www.freedesktop.org/wiki/Software/systemd/resolved
https://www.freedesktop.org/wiki/Software/systemd/writing-network-configuration-managers
https://www.freedesktop.org/wiki/Software/systemd/writing-resolver-clients
Main PID: 592 (systemd-resolve)
Status: "Processing requests..."
Tasks: 1 (limit: 7061)
Memory: 9.4M
CGroup: /system.slice/systemd-resolved.service
└─592 /lib/systemd/systemd-resolved
Oct 05 09:55:47 invasion-ubuntu20 systemd[1]: Starting Network Name Resolution...
Oct 05 09:55:47 invasion-ubuntu20 systemd-resolved[592]: Positive Trust Anchors:
Oct 05 09:55:47 invasion-ubuntu20 systemd-resolved[592]: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
Oct 05 09:55:47 invasion-ubuntu20 systemd-resolved[592]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.>
Oct 05 09:55:47 invasion-ubuntu20 systemd-resolved[592]: Using system hostname 'invasion-ubuntu20'.
Oct 05 09:55:47 invasion-ubuntu20 systemd[1]: Started Network Name Resolution.
Oct 05 09:55:47 invasion-ubuntu20 systemd-resolved[592]: Using degraded feature set (UDP) for DNS server 192.168.6.1.
